Good day
- Could you please advise if terminal block Terminal block Weidmüller WDU 10 – 1020300000 can handle connections of two conductors of 10mm2 cross section area at single point of connection. Is this type of connection allowed as per electrical standard or do we need to use jumper like WQV 10/2?
- Are WQV 10/2 jumper compatible to be used with WDU 10 in terms of current carrying capacity and voltage?
Regards
Ben
