I have noticed on many ceramic capacitors the thickness given by DigiKey does not match the manufacturer’s data sheet.
For example for P/N 1206YD226MAT2A the thickness given by DigiKey is 1.78mm but the AVX datasheet says it is 2.29mm.
So I do not think I can trust the value given by DigiKey.
Welcome to the TechForum.
Thank you for bringing this to our attention. I have notified the appropriate department to have the thickness updated.
