When looking at ESD protection diodes from Toshiba, you may find the suffixes “L” and “M” at the end of your part numbers which are not published in the datasheet, such as DF5A3.6JE,LM.
- L: Tape and reel
- M: Internal nomenclature for a specific Toshiba production line
Here are the part naming conventions for ESD Protection Diodes, such as DF5A6.2LFU.
| DF | 5 | A | 6.2 | L | FU |
| Toshiba ESD-Protection Diode | Package pin count | Internal configuration | Clamp voltage (Vbr) | Series | Package style |
| Note:The digit 7 denotes 1 6-pin package | Example: A - Common anode | Example: L - Ultra-high speed |
Appliable Part Numbers
DF5A3.6JE(TE85L,F) DF5A3.6JE,LM DF5A6.2CJE,LM
DF5A3.6JE(TE85LF)CT-ND DF5A3.6JE(TE85LF)DKR-ND DF5A3.6JELMCT-ND
DF5A3.6JELMDKR-ND DF5A3.6JELMTR-ND DF5A6.2CJELMTR-ND
