I have transform marked ST4810CF-25SENP. There are no other markings. It could be a 110v to 9v or 12v for a small cd player. I need enough info to replace it. Thanks!
The part number mentioned doesn’t seem to be fetching results from the usual sources, so we’ll not likely be able to provide you with any information about it. There are likely markings or information in the manual for the equipment that is being powered which could aid selection of a replacement, and some factors such as output connector size which can be directly measured.
