Do you have an adapter to go from a barrel output connector of 2.1mm ID X 5.5 mm OD X 11 mm
And then adapt to a plug as shown in the attached photo
So I want a female barrel to male plug.
Thank you for your inquiry and welcome to the community.
Is this the kind of thing you’re looking for?
That looks like it.
Thanks for the quick reply!
Rob
Hello again,
I am now looking for a transformer for my turntable.
120 volt ac to 32 volt dc with about the same wattage (60w) as the one I bought from you already.
Do you have one in stock?
Or another question does a 2 volt dc reduction make a difference to my motor.
The stock transformer is 32 volt x 15 watt output.
Part 1866-3692-ND
I don’t see that we have any AC/DC Adapters that have a 32VDC output in that wattage range.
It’s hard to say if the 2 volts reduction would be an issue, it would be depend upon the design of the circuit.
I removed the screen capture you shared as it contained personal information.
Please be aware that this is a public forum and is frequently scrapped by bots.
