Tricks For Searching Enclosures
I would like to share a method I use to help narrow down the myriad of options found under our Boxes, Enclosures, Racks > Boxes.
First I like to start with searching by the area. Figure out the LxW and get a sense of the area you need. Then select the values near this within reason for your application. Apply this filter. This should greatly reduce the amount of LxW options available listed under Size/Dimension.
Next I like to select the height, again selecting values near your requirement leaving some wiggle room. Apply this filter.
With these two filters applied it should be a lot easier to look through the Size/Dimension parameter choosing the best LxW combination for your application.
Additional filtering that can help narrow the list would be clicking the check box for in stock and also selecting Active under the Part Status.
If you are interested in learning more about custom capabilities regarding modifications for box/enclosures please take a look at this post linked below.
