Hi there I am looking for some help in adding tv tuner to a rpi cm4.I am designing a carrier board for the cm4 and would like to add tv tuner for dvb c if possible. Thank you mathew
Welcome to the DigiKey TechForum. Take a look at DigiKey part 1690-1027-ND as a possible option . I do see on the datasheet it supports standards: DVB-T2, DVB-T so I’m not sure if this will work for you.
