Hi,
Which communication cable do i need to be able to connect to the attached PCB bord?
You can see I have a communication unit named “PICkit”
Thank you so much!
Hi,
Thank you so much!
Greetings,
I am not aware of any standard cable designed to make this connection.
The functions of the 6-position PICkit2 connector are described in its documentation:
It would be necessary to find similar information describing the functions of the different pins on your board’s connector in order to construct an interface cable.
That said, it would appear that the processor shown is an ARM-based device, which would have used a different set of development tools than the Microchip products from the era of the PICkit2. Identifying the programming tools originally intended for use with your board/processor and using those will likely offer a better chance of success.
