UL flame rating?
Need help determining the flame rating of a micro coax cable:
UFL-2LPVHF6-04N1TV-A-100
Looks to be UL-94V0 except for an insulator in the receptacle?
Data sheet:
https://www.hirose.com/en/product/document?clcode=CL0321-0030-0-08&productname=U.FL-2LPHF6-04N1TV-A-100&series=U.FL&documenttype=Catalog&lang=en&documentid=D31697_en
Hello Chanderson and welcome to the TechForum.
For UFL-2LPVHF6-04N1TV-A-100 page 2 of the datasheets (U.FL_Catalog_ed_U.FL_CAT.pdf (1.1 MB))
does show the UL94 ratings of the patch cables. The metallic pieces are not UL rated (The Bronze and Brass components). This makes sense, as UL94 is a standard that addresses plastics.
So, would you consider this assembly UL-94V0 rated?
I am hearing through my supply chain folks it is only HB
Under the Plug-right angle table, there is one material listed as -HB. Datasheet.
From what I am able to locate, they are all UL94V rated
