Updated Mechanical Dimension Provided by E‑Switch 200USP9T1A1M2RE
If you observe a dimensional discrepancy in part 200USP9T1A1M2RE from E‑Switch, the drawing specifies this dimension as 3.45 mm ± 0.25 mm, while the measured dimension on the actual part is 3.95 mm.
We have confirmed this with the manufacturer, and as per them:
“Our drawing is wrong. The dimension should be 3.95 mm, which aligns with the measured dimension on the part. The dimension and the product have always been 3.95 mm. It will take about a week for us to update our drawings to show the correct dimension.”
Please note that the correct dimension is 3.95 mm, and the datasheet will be updated accordingly.
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
EG4915-ND 200USP1T1A1M2RE
EG4911-ND 200UDP1T1A1M2RE
EG4914-ND 200USP9T1A1M2RE
EG4912-ND 200USP1T1A1M6RE
EG4916-ND 200USP1T1A1M7RE
EG4913-ND 200USP3T1A1M6RE
EG4909-ND 200UDP1T1A1M6RE
EG4910-ND 200UDP1T1A1M7RE
141-200USP3T1A1M2RE-ND 200USP3T1A1M2RE
141-200UDP3T1A1M7RE-ND 200UDP3T1A1M7RE
141-200UDP3T1A1M6RE-ND 200UDP3T1A1M6RE
141-200USP3T1A1M7RE-ND 200USP3T1A1M7RE
141-200USP9T1A1M6RE-WHTBODY-ND 200USP9T1A1M6RE-WHTBODY
