I am reaching out to inquire about suitable components for establishing a full-duplex RS485 communication link between a host computer and a device that uses an RJ-11 male connector for serial interfacing.
I am specifically looking for one of the following:
A USB to RS485 converter that supports full-duplex communication and terminates in an RJ-11 female connector, or
A combination of components (e.g., USB to RS485 module + RJ-11 breakout or adapter etc.) that can be assembled without requiring soldering, wiring, or custom fabrication.
My preference is for a plug-and-play solution that can be easily integrated into my setup with minimal AIT effort. Ideally, the product or combination of products should be ready to use out of the box and compatible with standard USB drivers for Windows/Linux.
Any leads to the appropriate products will be highly appreciated.
Welcome and thank you for posting in the TechForum.
I did some research, and I think the combination of these 2 things might work for you. Take a look at part numbers 2084-BB-USPTL4-LS-ND and 3132-ST-RJ11-R-MIN-ND. I’m not positive because I’ve never used this setup, but it’s a starting point. Maybe one of our Engineers would have a better solution.
