UV resistance Hammond Manufacturing ABS Enclosures
Hi,
In the ABS Enclosures datasheet I did not find any information about UV resistance.
I using Hammond Manufacturing 1591DF2SGY and I wonder what is it UV resistance? Does the black get a better UV resistance than the gray ?
Thank you for you help and advice.
Laurent
If you’re looking for better UV resistance then you should consider changing from ABS – Acrylonitrile Butadiene Styrene to polycarbonate plastic material, that is more impact resistant, higher strength, durable and can withstand any harsh weather conditions.
Hammond Manufacturing is offering similar sizes as:
1591DTCL as BOX PLSTC TRN CLR 5.91"LX3.15"W meaning CLEAR or
1591DTBU as BOX PLAS BLUE 5.906"L X 3.15"W or
1591DTRD as BOX PLSTC TRN RED 5.91"LX3.15"W
for not so much more money…
