Video Card 0 Ohm resistor ID
I have a high end video card here with a blown 0 ohm resistor (I assume its used as a fuse) the video card boots fine (I hear Windows but see nothing) I assume this fuse powers the output chip for HDMI & DisplayPort.
Looking up 0 ohm resistors I see they come in many wattages 10w 16w etc is there anyway to know which 0 ohm resistor I have from looking at it?
Woops typo I meant to type 1/10w and 1/16w
Welcome to the TechForum.
The best way is probabaly by size, the measurement of your old resistor will closely match the size/dimension listed and then you can filter down to the correct one.
This is a good active list for our stock.
0 Ohm options
Thank you
Ryan
