Want to confirm the part number MFR: VISHAY, MFG#: SD200R20PC is the same as Digi-Key part number VS-SD200R20PC.
My description: DESCRIPTION: DIODE - 200 AMP, 1800 VOLT CAPACITOR MODULE, LINE/INVERTER FILTER CAP
Appreciate your response - request is Time-Sensitive.
Good Day -
Thank you so much.
Best regards,
Carolyn Whitaker | All-American Industrial Supplies
For future reference, since @Rhonda_1175 has already answered your question most excellently, if you look at the bottom of the page that she referenced, there is a heading called “Additional Resources”. Under this heading is a section called “Other Names”. If you look in this section, you’ll see that another name for the VS-SD200R20PC is the SD200R20PC. It’s an additional resource if there is ever any ambiguity about whether a part might have a different name or something to that effect.
