Voltage Adjustment
------Question for RSP-2000-48 Please Put your question below------
Can this power supply be adjusted to 52 volts?
According the datasheet, these are adjustable, between 42V and 56V..
Regards,
Yes you will be able to dial in the exact Voltages from 42V-56V +/- 1%
In addition to the adjustment via the built-in potentiometer, the output voltage can be trimmed to 40~115% of the nominal voltage by applying
EXTERNAL VOLTAGE
Page 4 of the datasheet
EXTERNAL VOLTAGE
Thank you
Ryan
Thanks you
Rather obvious when you read the right document.
Cheers
