Washing/Cleaning condition for Film Capacitor FKP0D001000B00JSSD from WIMA
In principle, all plastic-encapsulated components, regardless of the manufacturer are not to be regarded as hermetically sealed. This category also includes the film capacitor FKP0D001000B00JSSD from WIMA.
All washing processes are not suitable for similar components/items. During the washing process, washing substances can penetrate into the interior of the component by capillary action if microcracks occur due to the excessive soldering heat. A number of influencing factors are decisive for this, such as:
  • Type of washing agent
  • Viscosity of the washing solution
  • Temperature/duration of the washing process
  • Mechanical washing support, such as:
    • Ultrasound
    • Pressurized water
    • Rinsing/spray pressure
The type of detergent used is primarily user-specific or is often specified by the manufacturer of the washing system. Accordingly, the possible aggressiveness of the detergent used can only be assessed in connection with the respective washing process in suitable test series.
In many cases, the basic rule is to make the washing process as gentle as possible.
During the washing, aqueous solutions can penetrate the component. This can lead to a change in the electrical parameters. Suitable drying measures must be taken to ensure that no residual moisture or residues of washing substances remain in the component.
Additional technical information can be found in the current WIMA main catalogue or at www.wima.de.
It has been established that no complaints have been received from customers due to unacceptable deviations when washing processes have been used correctly in connection with wired capacitors in cans/encapsulated encapsulation.
In order to ensure that an unfavorable influence on the capacitor(s) can be ruled out in this case, the suitability for the washing process should be tested in a practical test at the user/assembler in accordance with the above information.
Applicable part Numbers
DK Part # Mfr Part #
1928-1238-ND FKP2D006801D00KSSD
1928-1252-ND FKP2F001501D00JSSD
1928-1223-ND FKP2C016801D00JSSD
1928-1242-ND FKP2D014701G00JSSD
1928-1314-ND FKP3G012203D00JSSD
1928-1291-ND FKP2O101001D00KSSD
1928-1271-ND FKP2G004701D00KSSD
1928-1266-ND FKP2G001001D00KSSD
1928-1268-ND FKP2G002201D00KSSD
1928-1239-ND FKP2D011001D00KSSD
1928-1219-ND FKP2C012201D00KSSD
1928-1220-ND FKP2C013301D00KSSD
1928-1267-ND FKP2G002201D00JSSD
1928-1038-ND FKP0C004700B00KSSD
1928-1265-ND FKP2G001001D00JSSD
1928-1293-ND FKP2O101501D00JSSD
1928-1215-ND FKP2C001501D00JSSD
1928-1236-ND FKP2D003301D00JSSD
1928-1253-ND FKP2F003301D00JSSD
1928-1294-ND FKP2O102201D00JSSD
1928-1043-ND FKP0D002200B00KSSD
1928-1256-ND FKP2F011001D00JSSD
1928-1047-ND FKP0D006800B00KSSD
1928-1270-ND FKP2G004701D00JSSD
1928-1278-ND FKP2J004701D00JSC9
1928-1224-ND FKP2C021501I00JSSD
1928-1290-ND FKP2O100681D00KSSD
1928-1258-ND FKP2F012201D00JSSD
1928-1240-ND FKP2D012201D00JSSD
1928-1243-ND FKP2D014701G00KSSD
1928-1222-ND FKP2C014701D00JSSD
1928-1295-ND FKP2O104701G00JSSD
1928-1287-ND FKP2O100331D00KSSD
1928-1289-ND FKP2O100471D00KSSD
1928-1299-ND FKP2O111001I00JSSD
1928-1244-ND FKP2D016801G00JSSD
1928-1277-ND FKP2J003301D00HSSD
1928-1217-ND FKP2C006801D00HSSD
1928-1269-ND FKP2G004701D00HSSD
1928-1255-ND FKP2F011001D00HSSD
1928-1272-ND FKP2G011001D00HSSD
1928-1323-ND FKP3J004702B00JSSD
1928-1275-ND FKP2G011501D00HSSD
1928-1280-ND FKP2J013301I00HSSD
1928-1296-ND FKP2O106801G00HSSD
1928-1328-ND FKP3O103302B00KSSD
1928-1045-ND FKP0D003300B00KSSD
1928-1260-ND FKP2F016801I00HSSD
1928-1241-ND FKP2D014701G00HSSD
1928-1228-ND FKP2C022201J00JSSD
1928-1048-ND FKP0D012200C00KSSD
1928-1055-ND FKP0F011000B00KSSD
1928-1324-ND FKP3J011503D00JSSD
1928-1227-ND FKP2C022201J00HSSD
1928-1039-ND FKP0D001000B00JSSD
1928-1037-ND FKP0C004700B00JSSD
1928-1262-ND FKP2F021001J00HSSD
1928-1248-ND FKP2D022201L00JSSD
1928-1040-ND FKP0D001500B00JSSD
1928-1042-ND FKP0D002200B00JSSD
1928-1231-ND FKP2C023301L00HSSD
1928-1054-ND FKP0D021000F00JSSD
1928-1302-ND FKP3C031004C00JSSD
1928-1276-ND FKP2J001001D00ESSD
1928-1216-ND FKP2C001501D00KSSD
1928-1274-ND FKP2G011001D00KSSD
1928-1273-ND FKP2G011001D00JSSD
1928-1237-ND FKP2D003301D00KSC4
1928-1279-ND FKP2J012201G00JSSD
1928-1049-ND FKP0D013300D00JSSD
1928-1338-ND FKP4J021004B00MSSD
1928-1322-ND FKP3J003302B00KSSD
1928-1307-ND FKP3F011002B00KSSD
1928-1311-ND FKP3G011002B00KSSD
1928-1315-ND FKP3G013303D00JSSD
1928-1332-ND FKP3O112203D00KSSD
1928-1282-ND FKP2J016801J00HSSD
1928-1053-ND FKP0D016800E00KSSD
1928-1232-ND FKP2C023301L00JSSD
1928-1340-ND FKP4O121504D00JSSD
1928-1310-ND FKP3F022204C00KSSD
1928-1341-ND FKP4O122204F00JSSD
1928-1306-ND FKP3D031004D00KSSD
1928-1350-ND FKP4U022206B00KSSD
1928-1349-ND FKP4U022206B00JSSD
1928-1329-ND FKP3O104702B00JSSD
1928-1331-ND FKP3O104702B00MSSD
1928-1303-ND FKP3D013302B00KSSD
1928-1230-ND FKP2C022201J00KSSD
1928-1312-ND FKP3G012202C00KSSD
1928-1057-ND FKP0G003300B00KSSD
1928-1316-ND FKP3G013303D00KSSD
1928-1339-ND FKP4O121004C00MSSD
1928-1052-ND FKP0D014700E00KSSD
1928-1351-ND FKP4U024706F00JSSD
4499-FKP2D003901D00HSSD-ND FKP2D003901D00HSSD
4499-FKP2D001201D00HSSD-ND FKP2D001201D00HSSD
4499-FKP2C015601D00HSSD-ND FKP2C015601D00HSSD
4499-FKP2C015101D00HSSD-ND FKP2C015101D00HSSD
4499-FKP2G000471A00JSSD-ND FKP2G000471A00JSSD
4499-FKP2D006201D00HSP4-ND FKP2D006201D00HSP4
4499-FKP2C013601D00HSSD-ND FKP2C013601D00HSSD
4499-FKP2C001201A00HSSD-ND FKP2C001201A00HSSD
4499-FKP2C021001G00HSP1-ND FKP2C021001G00HSP1
4499-FKP2D012401D00HSSD-ND FKP2D012401D00HSSD
4499-FKP0D011500B00JSSD-ND FKP0D011500B00JSSD
4499-FKP2D011801D00HSSD-ND FKP2D011801D00HSSD
4499-FKP2C017501G00HSSD-ND FKP2C017501G00HSSD
4499-FKP2J011201D00HSSD-ND FKP2J011201D00HSSD
4499-FKP2D004701D00JSSD-ND FKP2D004701D00JSSD
4499-FKP2J001001D00JSSD-ND FKP2J001001D00JSSD
4499-FKP2J000391D00HSSD-ND FKP2J000391D00HSSD
4499-FKP2D011001D00JSSD-ND FKP2D011001D00JSSD
4499-FKP0C012200C00JSSD-ND FKP0C012200C00JSSD
4499-FKP2D011501D00JSSD-ND FKP2D011501D00JSSD
4499-FKP0C014700E00JSSD-ND FKP0C014700E00JSSD
4499-FKP2C013301D00JSSD-ND FKP2C013301D00JSSD
4499-FKP2J002201D00HSSD-ND FKP2J002201D00HSSD
4499-FKP2G002201D00HSSD-ND FKP2G002201D00HSSD
4499-FKP2J004701D00HSSD-ND FKP2J004701D00HSSD
4499-FKP2O100471D00JSSD-ND FKP2O100471D00JSSD
4499-FKP2D003301D00HSSD-ND FKP2D003301D00HSSD
4499-FKP2O100331D00JSSD-ND FKP2O100331D00JSSD
4499-FKP2D004701D00HSSD-ND FKP2D004701D00HSSD
4499-FKP2C016801D00HSSD-ND FKP2C016801D00HSSD
4499-FKP2C012201D00HSSD-ND FKP2C012201D00HSSD
4499-FKP2G006801D00HSSD-ND FKP2G006801D00HSSD
4499-FKP2D008201D00HSSD-ND FKP2D008201D00HSSD
4499-FKP2D011501D00HSSD-ND FKP2D011501D00HSSD
4499-FKP2D001001D00HSSD-ND FKP2D001001D00HSSD
4499-FKP2D002201D00HSSD-ND FKP2D002201D00HSSD
4499-FKP2D013301G00HSSD-ND FKP2D013301G00HSSD
4499-FKP2D012201D00HSSD-ND FKP2D012201D00HSSD
4499-FKP2D021001I00JSSD-ND FKP2D021001I00JSSD
4499-FKP2D006801D00HSSD-ND FKP2D006801D00HSSD
4499-FKP2F006801D00HSSD-ND FKP2F006801D00HSSD
4499-FKP2D011001D00HSSD-ND FKP2D011001D00HSSD
4499-FKP2C014701D00HSSD-ND FKP2C014701D00HSSD
4499-FKP2C013301D00HSSD-ND FKP2C013301D00HSSD
4499-FKP2C021001G00HSSD-ND FKP2C021001G00HSSD
4499-FKP2C021801J00HSSD-ND FKP2C021801J00HSSD
4499-FKP3J003302B00JSSD-ND FKP3J003302B00JSSD
4499-FKP2D012701D00HSSD-ND FKP2D012701D00HSSD
4499-FKP3J001002B00JSSD-ND FKP3J001002B00JSSD
4499-FKP2J014701I00HSSD-ND FKP2J014701I00HSSD
4499-FKP0F002200B00HSSD-ND FKP0F002200B00HSSD
4499-FKP2C021501I00HSSD-ND FKP2C021501I00HSSD
4499-FKP2G016801J00HSSD-ND FKP2G016801J00HSSD
4499-FKP3J012203D00JSSD-ND FKP3J012203D00JSSD
4499-FKP4T012204C00KSSD-ND FKP4T012204C00KSSD
4499-FKP2D021501J00HSSD-ND FKP2D021501J00HSSD
4499-FKP0C021000F00HSSD-ND FKP0C021000F00HSSD
4499-FKP3O114703G00JSSD-ND FKP3O114703G00JSSD
4499-FKP3F021503G00JSSD-ND FKP3F021503G00JSSD
1928-1264-ND FKP2F021501L00KSSD
4499-FKP3J021004C00JSSD-ND FKP3J021004C00JSSD
4499-FKP3D023303G00JSSD-ND FKP3D023303G00JSSD
4499-FKP3G022204D00JSSD-ND,1928-1320-ND FKP3G022204D00JSSD
4499-FKP2D001001D00ESSD-ND FKP2D001001D00ESSD
4499-FKP2D004701D00ESSD-ND FKP2D004701D00ESSD
4499-FKP2J003301D00ESSD-ND FKP2J003301D00ESSD
4499-FKP2C014701D00ESSD-ND FKP2C014701D00ESSD
4499-FKP2D021501J00ESSD-ND FKP2D021501J00ESSD
4499-FKP2D012201D00ESSD-ND FKP2D012201D00ESSD
1928-1327-ND FKP3J022204J00JSSD
4499-FKP2D011001D00ESSD-ND FKP2D011001D00ESSD
4499-FKP4T031006I00JSSD-ND FKP4T031006I00JSSD
4499-FKP4G034706G00JSSD-ND FKP4G034706G00JSSD
4499-FKP2J011201D00HI00TR-ND FKP2J011201D00HI00
4499-FKP3G012203A00KSSD-ND FKP3G012203A00KSSD
4499-FKP2J001501D00JSSD-ND FKP2J001501D00JSSD
4499-FKP2J003301D00KI00TR-ND FKP2J003301D00KI00
4499-FKP2C011001D00JF00TR-ND FKP2C011001D00JF00
4499-FKP2D001001D00KSSD-ND FKP2D001001D00KSSD
4499-FKP2D003301D00JF00TR-ND FKP2D003301D00JF00
4499-FKP2D011501D00JI00TR-ND FKP2D011501D00JI00
4499-FKP2J001501D00JF00TR-ND FKP2J001501D00JF00
4499-FKP2D006801D00JI00TR-ND FKP2D006801D00JI00
4499-FKP2O102201D00JI00TR-ND FKP2O102201D00JI00
4499-FKP2G004701D00JI00TR-ND FKP2G004701D00JI00
4499-FKP2J001001D00JI00-ND FKP2J001001D00JI00
4499-FKP2O106801G00JI00TR-ND FKP2O106801G00JI00
4499-FKP2O102201D00HSSD-ND FKP2O102201D00HSSD
4499-FKP2J006801D00HSSD-ND FKP2J006801D00HSSD
4499-FKP2J011001D00HSSD-ND FKP2J011001D00HSSD
4499-FKP2O100681D00JF00TR-ND FKP2O100681D00JF00
4499-FKP2C003301D00HSSD-ND FKP2C003301D00HSSD
4499-FKP2D021001I00KSSD-ND FKP2D021001I00KSSD
4499-FKP2D006801D00HI00TR-ND FKP2D006801D00HI00
4499-FKP4J014704B00JSSD-ND FKP4J014704B00JSSD
4499-FKP2F014701I00JSSD-ND FKP2F014701I00JSSD
4499-FKP3O101002B00KSSD-ND FKP3O101002B00KSSD
4499-FKP3G012203D00KSSD-ND FKP3G012203D00KSSD
4499-FKP2C011001D00HF00TR-ND FKP2C011001D00HF00
4499-FKP2J011501D00HA00TR-ND FKP2J011501D00HA00
4499-FKP2D011501D00HI00TR-ND FKP2D011501D00HI00
4499-FKP3D014702B00JSSD-ND FKP3D014702B00JSSD
4499-FKP2O100331D00JI00TR-ND FKP2O100331D00JI00
4499-FKP2O100471D00JI00TR-ND FKP2O100471D00JI00
4499-FKP3J001502B00JSSD-ND FKP3J001502B00JSSD
4499-FKP3J002202B00JSSD-ND FKP3J002202B00JSSD
4499-FKP0D002200B00HSSD-ND FKP0D002200B00HSSD
4499-FKP3G012202C00JI00TR-ND FKP3G012202C00JI00
4499-FKP3D021002C00JSSD-ND FKP3D021002C00JSSD
4499-FKP4G021004B00JSSD-ND FKP4G021004B00JSSD
4499-FKP3O111503D00JSSD-ND FKP3O111503D00JSSD
4499-FKP4O121004C00JSSD-ND FKP4O121004C00JSSD
4499-FKP3O113303F00JSSD-ND FKP3O113303F00JSSD
4499-FKP2F021501L00HSSD-ND FKP2F021501L00HSSD
4499-FKP3C031004C00KSSD-ND FKP3C031004C00KSSD
4499-FKP3J021504F00JSSD-ND FKP3J021504F00JSSD
4499-FKP3C032204J00KSSD-ND FKP3C032204J00KSSD
4499-FKP4T031006I00KSSD-ND FKP4T031006I00KSSD
4499-FKP4T033307G00KSSD-ND FKP4T033307G00KSSD
1928-1298-ND FKP2O106801G00JSSD
1928-1218-ND FKP2C006801D00KSSD
1928-1250-ND FKP2F001501D00HSSD
1928-1283-ND FKP2J016801J00JSSD
1928-1304-ND FKP3D021503D00JSSD
1928-1334-ND FKP4G041006J00JSSD
4499-FKP2G001501D00JSSD-ND FKP2G001501D00JSSD
4499-FKP2G003301D00KSSD-ND FKP2G003301D00KSSD
4499-FKP2O101001D00JSSD-ND FKP2O101001D00JSSD
4499-FKP2O100681D00JSSD-ND FKP2O100681D00JSSD
4499-FKP2D001001D00JSSD-ND FKP2D001001D00JSSD
4499-FKP2C021001G00KSSD-ND FKP2C021001G00KSSD
4499-FKP2L011001G00HSSD-ND FKP2L011001G00HSSD
4499-FKP2J011501D00HSSD-ND FKP2J011501D00HSSD
4499-FKP2F003301D00HSSD-ND FKP2F003301D00HSSD
4499-FKP2J013301I00JSSD-ND FKP2J013301I00JSSD
4499-FKP2C011001D00HSSD-ND FKP2C011001D00HSSD
4499-FKP3J006802B00JSSD-ND FKP3J006802B00JSSD
4499-FKP2O111001I00HSSD-ND FKP2O111001I00HSSD
4499-FKP3O111002C00JSSD-ND FKP3O111002C00JSSD
4499-FKP2L012201I00HSSD-ND FKP2L012201I00HSSD
4499-FKP2J01821L00HSSD-ND FKP2J01821L00HSSD
1928-1226-ND FKP2C021501I00KSSD
4499-FKP3D028204C00HSSD-ND FKP3D028204C00HSSD
4499-FKP2L001501D00KSSD-ND FKP2L001501D00KSSD
4499-FKP2J000821D00HSSD-ND FKP2J000821D00HSSD
4499-FKP2J011501D00JSSD-ND FKP2J011501D00JSSD
4499-FKP3J013303F00HSSD-ND FKP3J013303F00HSSD
4499-FKP3D001002B00MSSD-ND FKP3D001002B00MSSD
4499-FKP2D001501D00HSSD-ND FKP2D001501D00HSSD
4499-FKP3G012202C00JSSD-ND FKP3G012202C00JSSD
4499-FKP2L013301J00HSSD-ND FKP2L013301J00HSSD
4499-FKP0G003300B00JSSD-ND FKP0G003300B00JSSD
4499-FKP3J013303F00KSSD-ND FKP3J013303F00KSSD
4499-FKP2G021001L00JSSD-ND FKP2G021001L00JSSD
4499-FKP3G014703F00JSSD-ND FKP3G014703F00JSSD
4499-FKP3J013303F00JSSD-ND FKP3J013303F00JSSD
4499-FKP3J016804B00JSSD-ND FKP3J016804B00JSSD
4499-FKP4R022205F00JSSD-ND FKP4R022205F00JSSD
4499-FKP3G023304F00JSSD-ND FKP3G023304F00JSSD
4499-FKP3C032204J00JSSD-ND FKP3C032204J00JSSD
4499-FKP4O133306I00JSSD-ND FKP4O133306I00JSSD
1928-1036-ND FKP0C003300B00KSSD
1928-1235-ND FKP2D001501D00KSSD
1928-1254-ND FKP2F003301D00KSSD
1928-FKP2L001501D00KSSD-ND FKP2L001501D00KSSD
1928-FKP2D001001D00KSSD-ND FKP2D001001D00KSSD
1928-FKP2G001501D00KSSD-ND FKP2G001501D00KSSD
1928-FKP2O103301D00KSSD-ND FKP2O103301D00KSSD
1928-FKP2G003301D00KSSD-ND FKP2G003301D00KSSD
1928-1257-ND FKP2F011001D00KSSD
1928-1333-ND FKP4G001004B00KSSD
1928-1336-ND FKP4J001004B00KSSD
1928-FKP2J001501D00JSSD-ND FKP2J001501D00JSSD
1928-FKP2O103301D00JSSD-ND FKP2O103301D00JSSD
1928-FKP2D001001D00JSSD-ND FKP2D001001D00JSSD
1928-FKP2C001001D00JSSD-ND FKP2C001001D00JSSD
1928-FKP2L001501D00JSSD-ND FKP2L001501D00JSSD
1928-FKP2G001501D00JSSD-ND FKP2G001501D00JSSD
1928-FKP2O101001D00JSSD-ND FKP2O101001D00JSSD
1928-FKP2J001001D00JSSD-ND FKP2J001001D00JSSD
1928-FKP2J012201G00KSSD-ND FKP2J012201G00KSSD
1928-FKP2F004701D00JSSD-ND FKP2F004701D00JSSD
1928-FKP2D006801D00JSSD-ND FKP2D006801D00JSSD
1928-FKP2D004701D00JSSD-ND FKP2D004701D00JSSD
1928-FKP2D011001D00JSSD-ND FKP2D011001D00JSSD
1928-1251-ND FKP2F001501D00JSC9
1928-FKP2F011501D00JSSD-ND FKP2F011501D00JSSD
1928-FKP2J011501D00JSSD-ND FKP2J011501D00JSSD
1928-FKP2D011501D00JSSD-ND FKP2D011501D00JSSD
1928-1335-ND FKP4J001004B00JSSD
1928-FKP2C013301D00JSSD-ND FKP2C013301D00JSSD
1928-FKP2C021001G00KSSD-ND FKP2C021001G00KSSD
1928-FKP2J003301D00KI00TR-ND FKP2J003301D00KI00
1928-FKP2O100681D00JSSD-ND FKP2O100681D00JSSD
1928-1300-ND FKP2O111001I00KSSD
1928-FKP2G001501D00HSSD-ND FKP2G001501D00HSSD
1928-FKP2L001001D00HSSD-ND FKP2L001001D00HSSD
1928-FKP2G002201D00HSSD-ND FKP2G002201D00HSSD
1928-FKP2D003301D00HSSD-ND FKP2D003301D00HSSD
1928-FKP2C003301D00HSSD-ND FKP2C003301D00HSSD
1928-FKP2D001001D00HSSD-ND FKP2D001001D00HSSD
1928-FKP2D002201D00HSSD-ND FKP2D002201D00HSSD
1928-FKP2J001001D00HSSD-ND FKP2J001001D00HSSD
1928-FKP2D001501D00HSSD-ND FKP2D001501D00HSSD
1928-FKP2J002201D00HSSD-ND FKP2J002201D00HSSD
1928-FKP2F003301D00HSSD-ND FKP2F003301D00HSSD
1928-FKP2O102201D00HSSD-ND FKP2O102201D00HSSD
1928-FKP2O100331D00JSSD-ND FKP2O100331D00JSSD
1928-FKP2D004701D00HSSD-ND FKP2D004701D00HSSD
1928-FKP2J006801D00HSSD-ND FKP2J006801D00HSSD
1928-FKP2D006801D00HSSD-ND FKP2D006801D00HSSD
1928-FKP2J004701D00HSSD-ND FKP2J004701D00HSSD
1928-FKP2F006801D00HSSD-ND FKP2F006801D00HSSD
1928-FKP2G006801D00HSSD-ND FKP2G006801D00HSSD
1928-FKP2O103301D00JI00TR-ND FKP2O103301D00JI00
1928-FKP2D001001D00JI00TR-ND FKP2D001001D00JI00
1928-FKP2J001501D00JF00TR-ND FKP2J001501D00JF00
1928-FKP2O102201D00JI00TR-ND FKP2O102201D00JI00
1928-FKP2D003301D00JF00TR-ND FKP2D003301D00JF00
1928-FKP2O100471D00JSSD-ND FKP2O100471D00JSSD
1928-FKP2J001001D00JI00TR-ND FKP2J001001D00JI00
1928-FKP2D011001D00HSSD-ND FKP2D011001D00HSSD
1928-FKP2C011001D00HSSD-ND FKP2C011001D00HSSD
1928-FKP2J011001D00HSSD-ND FKP2J011001D00HSSD
1928-FKP2G004701D00JI00TR-ND FKP2G004701D00JI00
1928-FKP2D006801D00JI00TR-ND FKP2D006801D00JI00
1928-FKP2J011501D00HSSD-ND FKP2J011501D00HSSD
1928-FKP2D011501D00HSSD-ND FKP2D011501D00HSSD
1928-FKP3D001002B00MSSD-ND FKP3D001002B00MSSD
1928-FKP2C011001D00JF00TR-ND FKP2C011001D00JF00
1928-FKP2D011501D00JI00TR-ND FKP2D011501D00JI00
1928-FKP2C012201D00HSSD-ND FKP2C012201D00HSSD
1928-FKP2D012201D00HSSD-ND FKP2D012201D00HSSD
1928-1313-ND FKP3G012202C00MSSD
1928-FKP2J014701I00KSSD-ND FKP2J014701I00KSSD
1928-FKP2C013301D00HSSD-ND FKP2C013301D00HSSD
1928-FKP2C014701D00HSSD-ND FKP2C014701D00HSSD
1928-FKP2O106801G00JI00TR-ND FKP2O106801G00JI00
1928-FKP2O104701G00HSSD-ND FKP2O104701G00HSSD
1928-FKP2J013301I00JSSD-ND FKP2J013301I00JSSD
1928-FKP3O101002B00KSSD-ND FKP3O101002B00KSSD
1928-FKP2L011001G00HSSD-ND FKP2L011001G00HSSD
1928-FKP2C016801D00HSSD-ND FKP2C016801D00HSSD
1928-FKP2D021001I00KSSD-ND FKP2D021001I00KSSD
1928-FKP3J011002C00KSSD-ND FKP3J011002C00KSSD
1928-FKP3G011502C00KSSD-ND FKP3G011502C00KSSD
1928-FKP2F013301G00JI00TR-ND FKP2F013301G00JI00
1928-FKP2G013301G00HSSD-ND FKP2G013301G00HSSD
1928-FKP2D013301G00HSSD-ND FKP2D013301G00HSSD
1928-FKP2F014701I00JSSD-ND FKP2F014701I00JSSD
1928-FKP2O100681D00JF00TR-ND FKP2O100681D00JF00
1928-FKP2C021001G00HSSD-ND FKP2C021001G00HSSD
1928-FKP3G012203D00KSSD-ND FKP3G012203D00KSSD
1928-FKP3J001002B00JSSD-ND FKP3J001002B00JSSD
1928-FKP3J003302B00JSSD-ND FKP3J003302B00JSSD
1928-FKP3D014702B00JSSD-ND FKP3D014702B00JSSD
1928-FKP3J001502B00JSSD-ND FKP3J001502B00JSSD
1928-FKP3O101002B00JSSD-ND FKP3O101002B00JSSD
1928-FKP3J006802B00JSSD-ND FKP3J006802B00JSSD
1928-FKP3J002202B00JSSD-ND FKP3J002202B00JSSD
1928-FKP2O102201D00HI00TR-ND FKP2O102201D00HI00
1928-FKP2D021001I00JSSD-ND FKP2D021001I00JSSD
1928-FKP3G012202C00JSSD-ND FKP3G012202C00JSSD
1928-FKP3O111002C00JSSD-ND FKP3O111002C00JSSD
1928-FKP2D006801D00HI00TR-ND FKP2D006801D00HI00
1928-FKP2O100331D00JI00TR-ND FKP2O100331D00JI00
1928-FKP2L012201I00HSSD-ND FKP2L012201I00HSSD
1928-FKP2C011001D00HF00TR-ND FKP2C011001D00HF00
1928-FKP2O100471D00JI00TR-ND FKP2O100471D00JI00
1928-1261-ND FKP2F016801I00JSSD
1928-FKP2J011501D00HA00TB-ND FKP2J011501D00HA00
1928-FKP2D011501D00HI00TR-ND FKP2D011501D00HI00
1928-1284-ND FKP2J016801J00MSC9
1928-FKP2O111001I00HSSD-ND FKP2O111001I00HSSD
1928-1046-ND FKP0D003300B00MSSD
1928-FKP2J014701I00HSSD-ND FKP2J014701I00HSSD
1928-FKP2C021001G00HF00TR-ND FKP2C021001G00HF00
1928-1321-ND FKP3J001502B00JSC9
1928-FKP3F013303A00JSSD-ND FKP3F013303A00JSSD
1928-FKP2L013301J00HSSD-ND FKP2L013301J00HSSD
1928-1337-ND FKP4J021004B00KSSD
1928-FKP3D014702B00JI00TR-ND FKP3D014702B00JI00
1928-FKP2D021001I00HSSD-ND FKP2D021001I00HSSD
4499-FKP2F004701D00JSSD-ND FKP2F004701D00JSSD
1928-FKP3G012202C00JI00TR-ND FKP3G012202C00JI00
1928-1041-ND FKP0D001500B00KSSD
1928-1035-ND FKP0C002200B00KSSD
1928-1246-ND FKP2D021501J00JSSD
1928-1286-ND FKP2J021001L00KSSD
1928-FKP2C021501I00HSSD-ND FKP2C021501I00HSSD
1928-FKP4T012204C00KSSD-ND FKP4T012204C00KSSD
1928-FKP3D021002C00JSSD-ND FKP3D021002C00JSSD
1928-FKP4G021004B00JSSD-ND FKP4G021004B00JSSD
1928-FKP3J012203D00JSSD-ND FKP3J012203D00JSSD
1928-FKP3O111503D00JSSD-ND FKP3O111503D00JSSD
1928-1051-ND FKP0D013300D00KSSD
1928-FKP3G014703F00KSSD-ND FKP3G014703F00KSSD
1928-FKP3J013303F00KSSD-ND FKP3J013303F00KSSD
1928-1263-ND FKP2F021501L00JSSD
1928-FKP2G021001L00JSSD-ND FKP2G021001L00JSSD
1928-1056-ND FKP0F012200D00KSSD
1928-FKP2G016801J00HSSD-ND FKP2G016801J00HSSD
4499-FKP2F011501D00JSSD-ND FKP2F011501D00JSSD
1928-1285-ND FKP2J021001L00JSC9
1928-1234-ND FKP2C023301L00KSSD
1928-1301-ND FKP3C023303D00KSSD
1928-1305-ND FKP3D021503D00KSSD
4499-FKP2J001001D00HSSD-ND FKP2J001001D00HSSD
1928-FKP3J013303F00JSSD-ND FKP3J013303F00JSSD
1928-FKP3G014703F00JSSD-ND FKP3G014703F00JSSD
1928-FKP3O113303F00JSSD-ND FKP3O113303F00JSSD
1928-FKP2D021501J00HSSD-ND FKP2D021501J00HSSD
4499-FKP2G021001L00HSP1-ND FKP2G021001L00HSP1
1928-FKP4O121004C00JSSD-ND FKP4O121004C00JSSD
1928-FKP2F021501L00HSSD-ND FKP2F021501L00HSSD
4499-FKP2O104701G00HSSD-ND FKP2O104701G00HSSD
1928-FKP2J021001L00HSSD-ND FKP2J021001L00HSSD
1928-FKP3J014703G00KSSD-ND FKP3J014703G00KSSD
4499-FKP0C003300B00HSSD-ND FKP0C003300B00HSSD
1928-FKP3F021503G00JSSD-ND FKP3F021503G00JSSD
1928-FKP3O114703G00JSSD-ND FKP3O114703G00JSSD
1928-FKP3J014703G00KI00TR-ND FKP3J014703G00KI00
1928-1319-ND FKP3G021504C00KSSD
1928-1317-ND FKP3G021004B00JSSD
1928-FKP3J016804B00JSSD-ND FKP3J016804B00JSSD
1928-1308-ND FKP3F022204C00JSSD
1928-1318-ND FKP3G021504C00JSSD
1928-1325-ND FKP3J021004C00JSSD
1928-FKP3D023303G00JSSD-ND FKP3D023303G00JSSD
1928-FKP3C031004C00KSSD-ND FKP3C031004C00KSSD
1928-1346-ND FKP4T021505F00KSSD
1928-FKP4U016805F00JSSD-ND FKP4U016805F00JSSD
1928-FKP4R022205F00JSSD-ND FKP4R022205F00JSSD
1928-1345-ND FKP4T021505F00JSSD
1928-1245-ND FKP2D016801G00KSSD
1928-1247-ND FKP2D021501J00KSSD
1928-1326-ND FKP3J021504F00JSSD
1928-FKP3G023304F00JSSD-ND FKP3G023304F00JSSD
1928-FKP4J031505I00KSSD-ND FKP4J031505I00KSSD
1928-FKP4T023306B00JSSD-ND FKP4T023306B00JSSD
1928-FKP3C032204J00KSSD-ND FKP3C032204J00KSSD
1928-FKP4T024706D00JSSD-ND FKP4T024706D00JSSD
1928-1348-ND FKP4U014705D00KSSD
1928-FKP3C032204J00JSSD-ND FKP3C032204J00JSSD
1928-1259-ND FKP2F016801I00ESSD
1928-FKP4G034706G00MSSD-ND FKP4G034706G00MSSD
1928-1343-ND FKP4O132206F00JSSD
1928-FKP4T031006I00KSSD-ND FKP4T031006I00KSSD
1928-1281-ND FKP2J016801J00ESSD
1928-FKP4T031006I00JSSD-ND FKP4T031006I00JSSD
4499-FKP2D002201D00ESSD-ND FKP2D002201D00ESSD
1928-FKP4G034706G00JSSD-ND FKP4G034706G00JSSD
1928-1347-ND FKP4T031506J00KSSD
1928-FKP4O133306I00JSSD-ND FKP4O133306I00JSSD
1928-1344-ND FKP4R032206J00KSSD
4499-FKP2D013301G00ESSD-ND FKP2D013301G00ESSD
1928-FKP4T033307G00KSSD-ND FKP4T033307G00KSSD
1928-FKP4J041007G00JSSD-ND FKP4J041007G00JSSD
4499-FKP2G001501D00KSSD-ND FKP2G001501D00KSSD
4499-FKP4O104704B00KSSD-ND FKP4O104704B00KSSD
4499-FKP4O102204B00KSSD-ND FKP4O102204B00KSSD
4499-FKP4J011504B00KSSD-ND FKP4J011504B00KSSD
4499-FKP2J014701I00KSSD-ND FKP2J014701I00KSSD
4499-FKP0C021000F00KSSD-ND FKP0C021000F00KSSD
4499-FKP3O101002B00JSSD-ND FKP3O101002B00JSSD
4499-FKP3F013303A00JSSD-ND FKP3F013303A00JSSD
4499-FKP3G014703F00KSSD-ND FKP3G014703F00KSSD
4499-FKP4J031505I00KSSD-ND FKP4J031505I00KSSD
4499-FKP4T023306B00JSSD-ND FKP4T023306B00JSSD
4499-FKP3C032204J00HSSD-ND FKP3C032204J00HSSD
4499-FKP4G034706G00MSSD-ND FKP4G034706G00MSSD
4499-FKP3C032204J00ESSD-ND FKP3C032204J00ESSD
4499-FKP4J036807G00KSSD-ND FKP4J036807G00KSSD
4499-FKP4J036807G00JSSD-ND FKP4J036807G00JSSD
4499-FKP4J041007G00JSSD-ND FKP4J041007G00JSSD
