We are trying to replace The Infineon module TZ240N34KOF
we are trying to replace The Infineon module TZ240N34KOF
The Voltage rating at least 2600 Volts
Our Peak current Is about 670 amps at 1 Hz rate.
please offer an alternate.
Hello VIP Components,
Thank you for using the DigiKey Techncial Forum
PN TZ240N36KOFHPSA1 is listed as a direct cross.
Compare Chart
I am sorry to inform you is it currently out of stock.
If you need something in stock now, you might consider the TZ400N26KOFHPSA1. It’s rated for your minimum 2600V, and otherwise seems to meet or exceed the other common specs. Here’s a comparison including your original part, Nathan’s very good but out of stock option, and this one.
