What is a Logic Level MOSFET?
Some of DigiKey’s FETs, MOSFETs have a “Logic Level Gate”.
What are these and what are they used for?
A Logic Level MOSFET indicates the device can be driven with “logic level” voltage, which typically was referred to as TTL (Transistor-Transistor Logic). “Logic level” voltages have become smaller over the years due to the use of advanced MOSFETS instead of the use of true TTL. You will notice each will have their own specified logic level voltage listed, or their “Drive”.
These are best used for high-speed switching since these are known to have low input capacitance or a low gate-charge, yet minimizing the on-state resistance (RDS(ON)) to maintain superior switching performance making them ideal for high-efficiency power management applications. Sometimes referred to as “gate drivers” since they are designed to accept logic-level control signals, such as from an Arduino, and provide what is effectively an amplified form more suitable for driving a higher voltage load, or large, high-voltage FETs. The advanced MOSFET technology commonly use Enhancement-Mode, or Trench technology.
Driving Parameters
Although the drive voltage is the nominal rating to “drive” or turn-on the device, there is some tolerance. For example, the “Absolute Maximum Gate-Source Voltage” will be listed in the datasheet, which is the absolute maximum voltage that can be applied to the gate in reference to the source, commonly of some magnitude higher.
There is also what is called the “Gate Threshold Voltage” expressed as “Vth”, which is the voltage applied between gate and source that causes the drain current (ID) to be specified under a certain value. Then, for normal switching operation, VGS(ON) must be higher than Vth, and VGS(OFF) must be lower than Vth. This relationship can be expressed as:
VGS(OFF) < Vth < VGS(ON)
Take this into consideration when using the device and refer to item specific datasheet for its exact driving parameters and other specifications.
Related Topics
Guide to Selecting and Controlling a MOSFET for 3.3 VDC Logic Applications
Applicable Part Numbers
|264-SSM6L56FELMTR-ND,264-SSM6L56FELMCT-ND,264-SSM6L56FELMDKR-ND|SSM6L56FE,LM|
|SSM6N37FULFTR-ND,SSM6N37FULFCT-ND,SSM6N37FULFDKR-ND|SSM6N37FU,LF|
|1727-PMDXB600UNEZTR-ND,1727-PMDXB600UNEZCT-ND,1727-1470-1-ND,1727-PMDXB600UNEZDKR-ND,1727-1470-6-ND|PMDXB600UNEZ|
|2N7002DWH6327XTSA1TR-ND,2N7002DWH6327XTSA1CT-ND,2N7002DWH6327XTSA1DKR-ND|2N7002DWH6327XTSA1|
|SSM6N44FELMTR-ND,SSM6N44FELMCT-ND,SSM6N44FELMDKR-ND|SSM6N44FE,LM|
|1727-6479-2-ND,1727-6479-1-ND,1727-6479-6-ND|BSS138PS,115|
|DMG1016UDW-7DITR-ND,DMG1016UDW-7DICT-ND,DMG1016UDW-7DIDKR-ND|DMG1016UDW-7|
|UM6K33NTNTR-ND,UM6K33NTNCT-ND,UM6K33NTNDKR-ND|UM6K33NTN|
|UM6K34NTCNTR-ND,UM6K34NTCNCT-ND,UM6K34NTCNDKR-ND|UM6K34NTCN|
|EM6K34T2CRTR-ND,EM6K34T2CRCT-ND,EM6K34T2CRDKR-ND|EM6K34T2CR|
|DMG6601LVT-7DITR-ND,DMG6601LVT-7DICT-ND,DMG6601LVT-7DIDKR-ND|DMG6601LVT-7|
|BSD840NH6327XTSA1TR-ND,BSD840NH6327XTSA1CT-ND,BSD840NH6327XTSA1DKR-ND|BSD840NH6327XTSA1|
|2N7002DWTR-ND,2N7002DWCT-ND,2N7002DWDKR-ND|2N7002DW|
|NTJD4401NT1GOSTR-ND,NTJD4401NT1GOSCT-ND,NTJD4401NT1GOSDKR-ND|NTJD4401NT1G|
|SSM6L14FE(TE85LF)TR-ND,SSM6L14FE(TE85LF)CT-ND,SSM6L14FE(TE85LF)DKR-ND|SSM6L14FE(TE85L,F)|
|BSD235NH6327XTSA1TR-ND,BSD235NH6327XTSA1CT-ND,BSD235NH6327XTSA1DKR-ND|BSD235NH6327XTSA1|
|SI1034CX-T1-GE3TR-ND,SI1034CX-T1-GE3CT-ND,SI1034CX-T1-GE3DKR-ND|SI1034CX-T1-GE3|
|1727-PMCXB900UEZTR-ND,1727-PMCXB900UEZCT-ND,1727-PMCXB900UEZDKR-ND|PMCXB900UEZ|
|DMG1029SV-7DITR-ND,DMG1029SV-7DICT-ND,DMG1029SV-7DIDKR-ND|DMG1029SV-7|
|NTZD3155CT1GOSTR-ND,NTZD3155CT1GOSCT-ND,NTZD3155CT1GOSDKR-ND|NTZD3155CT1G|
|SI1539CDL-T1-GE3TR-ND,SI1539CDL-T1-GE3CT-ND,SI1539CDL-T1-GE3DKR-ND|SI1539CDL-T1-GE3|
|SSM6N58NULFTR-ND,SSM6N58NULFCT-ND,SSM6N58NULFDKR-ND|SSM6N58NU,LF|
|BSS138DW-FDITR-ND,BSS138DW-FDICT-ND,BSS138DW-FDIDKR-ND|BSS138DW-7-F|
|SI1016CX-T1-GE3TR-ND,SI1016CX-T1-GE3CT-ND,SI1016CX-T1-GE3DKR-ND|SI1016CX-T1-GE3|
|SSM6N67NULFTR-ND,SSM6N67NULFCT-ND,SSM6N67NULFDKR-ND|SSM6N67NU,LF|
|FDC6301NTR-ND,FDC6301NCT-ND,FDC6301NDKR-ND|FDC6301N|
|BSS8402DW-FDITR-ND,BSS8402DW-FDICT-ND,BSS8402DW-FDIDKR-ND|BSS8402DW-7-F|
|DMN2004DWKDITR-ND,DMN2004DWKDICT-ND,DMN2004DWKDIDKR-ND|DMN2004DWK-7|
|NTJD4152PT1GOSTR-ND,NTJD4152PT1GOSCT-ND,NTJD4152PT1GOSDKR-ND|NTJD4152PT1G|
|SI1926DL-T1-E3TR-ND,SI1926DL-T1-E3CT-ND,SI1926DL-T1-E3DKR-ND|SI1926DL-T1-E3|
|DMC31D5UDJ-7DITR-ND,DMC31D5UDJ-7DICT-ND,DMC31D5UDJ-7DIDKR-ND|DMC31D5UDJ-7|
|NDC7002NTR-ND,NDC7002NCT-ND,NDC7002NDKR-ND|NDC7002N|
|785-1555-2-ND,785-1555-1-ND,785-1555-6-ND|AO4629|
|DMN3135LVT-7DITR-ND,DMN3135LVT-7DICT-ND,DMN3135LVT-7DIDKR-ND|DMN3135LVT-7|
|DMC3025LSD-13DITR-ND,DMC3025LSD-13DICT-ND,DMC3025LSD-13DIDKR-ND|DMC3025LSD-13|
|SI1026X-T1-GE3TR-ND,SI1026X-T1-GE3CT-ND,SI1026X-T1-GE3DKR-ND|SI1026X-T1-GE3|
|SI1025X-T1-GE3TR-ND,SI1025X-T1-GE3CT-ND,SI1025X-T1-GE3DKR-ND|SI1025X-T1-GE3|
|785-1078-2-ND,785-1078-1-ND,785-1078-6-ND|AO6604|
|EM6M2T2RTR-ND,EM6M2T2RCT-ND,EM6M2T2RDKR-ND|EM6M2T2R|
|SIA931DJ-T1-GE3TR-ND,SIA931DJ-T1-GE3CT-ND,SIA931DJ-T1-GE3DKR-ND|SIA931DJ-T1-GE3|
|DMC3021LSD-13DITR-ND,DMC3021LSD-13DICT-ND,DMC3021LSD-13DIDKR-ND|DMC3021LSD-13|
|SI1024X-T1-GE3TR-ND,SI1024X-T1-GE3CT-ND,SI1024X-T1-GE3DKR-ND|SI1024X-T1-GE3|
|DMG4800LSD-13DITR-ND,DMG4800LSD-13DICT-ND,DMG4800LSD-13DIDKR-ND|DMG4800LSD-13|
|FDY1002PZTR-ND,FDY1002PZCT-ND,FDY1002PZDKR-ND|FDY1002PZ|
|IRF9389TRPBFTR-ND,IRF9389TRPBFCT-ND,IRF9389TRPBFDKR-ND|IRF9389TRPBF|
|785-1294-2-ND,785-1294-1-ND,785-1294-6-ND|AO4614B|
|FDC6333CTR-ND,FDC6333CCT-ND,FDC6333CDKR-ND|FDC6333C|
|SIA533EDJ-T1-GE3TR-ND,SIA533EDJ-T1-GE3CT-ND,SIA533EDJ-T1-GE3DKR-ND|SIA533EDJ-T1-GE3|
|FDC6321CTR-ND,FDC6321CCT-ND,FDC6321CDKR-ND|FDC6321C|
|IRLHS6376TRPBFTR-ND,IRLHS6376TRPBFCT-ND,IRLHS6376TRPBFDKR-ND|IRLHS6376TRPBF|
|SI3932DV-T1-GE3TR-ND,SI3932DV-T1-GE3CT-ND,SI3932DV-T1-GE3DKR-ND|SI3932DV-T1-GE3|
|SIA910EDJ-T1-GE3TR-ND,SIA910EDJ-T1-GE3CT-ND,SIA910EDJ-T1-GE3DKR-ND|SIA910EDJ-T1-GE3|
|FDC6561ANTR-ND,FDC6561ANCT-ND,FDC6561ANDKR-ND|FDC6561AN|
|NTGD4167CT1GOSTR-ND,NTGD4167CT1GOSCT-ND,NTGD4167CT1GOSDKR-ND|NTGD4167CT1G|
|DMC4047LSD-13DITR-ND,DMC4047LSD-13DICT-ND,DMC4047LSD-13DIDKR-ND|DMC4047LSD-13|
|US6K4TR-ND,US6K4CT-ND,US6K4DKR-ND|US6K4TR|
|NTUD3170NZT5GOSTR-ND,NTUD3170NZT5GOSCT-ND,NTUD3170NZT5GOSDKR-ND|NTUD3170NZT5G|
|SIA975DJ-T1-GE3TR-ND,SIA975DJ-T1-GE3CT-ND,SIA975DJ-T1-GE3DKR-ND|SIA975DJ-T1-GE3|
|FDS8984TR-ND,FDS8984CT-ND,FDS8984DKR-ND|FDS8984|
|FDS9926ATR-ND,FDS9926ACT-ND,FDS9926ADKR-ND|FDS9926A|
|785-1317-2-ND,785-1317-1-ND,785-1317-6-ND|AO4882|
|785-1688-2-ND,785-1688-1-ND,785-1688-6-ND|AO4838|
|FDMA2002NZTR-ND,FDMA2002NZCT-ND,FDMA2002NZDKR-ND|FDMA2002NZ|
|DMC2020USD-13DITR-ND,DMC2020USD-13DICT-ND,DMC2020USD-13DIDKR-ND|DMC2020USD-13|
|DMP3036SSD-13DITR-ND,DMP3036SSD-13DICT-ND,DMP3036SSD-13DIDKR-ND|DMP3036SSD-13|
|785-1059-2-ND,785-1059-1-ND,785-1059-6-ND|AO4818B|
|DMHC3025LSD-13DITR-ND,DMHC3025LSD-13DICT-ND,DMHC3025LSD-13DIDKR-ND|DMHC3025LSD-13|
|785-1041-2-ND,785-1041-1-ND,785-1041-6-ND|AO4612|
|FDMA3023PZTR-ND,FDMA3023PZCT-ND,FDMA3023PZDKR-ND|FDMA3023PZ|
|FDC6327CTR-ND,FDC6327CCT-ND,FDC6327CDKR-ND|FDC6327C|
|FDS4559TR-ND,FDS4559CT-ND,FDS4559DKR-ND|FDS4559|
|785-1043-2-ND,785-1043-1-ND,785-1043-6-ND|AO4616|
|DMP4025LSD-13DITR-ND,DMP4025LSD-13DICT-ND,DMP4025LSD-13DIDKR-ND|DMP4025LSD-13|
|DMN4034SSD-13TR-ND,DMN4034SSD-13CT-ND,DMN4034SSD-13DKR-ND|DMN4034SSD-13|
|FDME1024NZTTR-ND,FDME1024NZTCT-ND,FDME1024NZTDKR-ND|FDME1024NZT|
|IRF7306PBFTR-ND,IRF7306PBFCT-ND,IRF7306PBFDKR-ND|IRF7306TRPBF|
|FDS4935BZTR-ND,FDS4935BZCT-ND,FDS4935BZDKR-ND|FDS4935BZ|
|FDMA1028NZTR-ND,FDMA1028NZCT-ND,FDMA1028NZDKR-ND|FDMA1028NZ|
|FDS8858CZTR-ND,FDS8858CZCT-ND,FDS8858CZDKR-ND|FDS8858CZ|
|IRF7380TRPBFTR-ND,IRF7380TRPBFCT-ND,IRF7380TRPBFDKR-ND|IRF7380TRPBF|
|SI6562CDQ-T1-GE3TR-ND,SI6562CDQ-T1-GE3CT-ND,SI6562CDQ-T1-GE3DKR-ND|SI6562CDQ-T1-GE3|
|FDMA1032CZTR-ND,FDMA1032CZCT-ND,FDMA1032CZDKR-ND|FDMA1032CZ|
|NTHD4102PT1GOSTR-ND,NTHD4102PT1GOSCT-ND,NTHD4102PT1GOSDKR-ND|NTHD4102PT1G|
|FDS4935ATR-ND,FDS4935ACT-ND,FDS4935ADKR-ND|FDS4935A|
|ZXMHC3F381N8DITR-ND,ZXMHC3F381N8DICT-ND,ZXMHC3F381N8DIDKR-ND|ZXMHC3F381N8TC|
|FDME1034CZTFSTR-ND,FDME1034CZTFSCT-ND,FDME1034CZTFSDKR-ND|FDME1034CZT|
|SI4909DY-T1-GE3TR-ND,SI4909DY-T1-GE3CT-ND,SI4909DY-T1-GE3DKR-ND|SI4909DY-T1-GE3|
|SI9926CDY-T1-GE3TR-ND,SI9926CDY-T1-GE3CT-ND,SI9926CDY-T1-GE3DKR-ND|SI9926CDY-T1-GE3|
|448-IRF7341TRPBFXTMA1TR-ND,448-IRF7341TRPBFXTMA1CT-ND,448-IRF7341TRPBFXTMA1DKR-ND|IRF7341TRPBFXTMA1|
|448-IPG16N10S4L61AATMA1TR-ND,448-IPG16N10S4L61AATMA1CT-ND,448-IPG16N10S4L61AATMA1DKR-ND|IPG16N10S4L61AATMA1|
|IRF7389PBFTR-ND,IRF7389PBFCT-ND,IRF7389PBFDKR-ND|IRF7389TRPBF|
|IPG20N04S4L11ATMA1TR-ND,IPG20N04S4L11ATMA1CT-ND,IPG20N04S4L11ATMA1DKR-ND|IPG20N04S4L11ATMA1|
|FDS6898ATR-ND,FDS6898ACT-ND,FDS6898ADKR-ND|FDS6898A|
|IPG20N06S4L26ATMA1TR-ND,IPG20N06S4L26ATMA1CT-ND,IPG20N06S4L26ATMA1DKR-ND|IPG20N06S4L26ATMA1|
|IRF7907TRPBFTR-ND,IRF7907TRPBFCT-ND,IRF7907TRPBFDKR-ND|IRF7907TRPBF|
|BSO150N03MDGXUMA1TR-ND,BSO150N03MDGXUMA1CT-ND,BSO150N03MDGXUMA1DKR-ND|BSO150N03MDGXUMA1|
|FDS8949TR-ND,FDS8949CT-ND,FDS8949DKR-ND|FDS8949|
|SI4931DY-T1-GE3TR-ND,SI4931DY-T1-GE3CT-ND,SI4931DY-T1-GE3DKR-ND|SI4931DY-T1-GE3|
|IRF9358TRPBFTR-ND,IRF9358TRPBFCT-ND,IRF9358TRPBFDKR-ND|IRF9358TRPBF|
|BSZ15DC02KDHXTMA1TR-ND,BSZ15DC02KDHXTMA1CT-ND,BSZ15DC02KDHXTMA1DKR-ND|BSZ15DC02KDHXTMA1|
|IRF7342PBFTR-ND,IRF7342PBFCT-ND,IRF7342PBFDKR-ND|IRF7342TRPBF|
|IRF7329PBFTR-ND,IRF7329PBFCT-ND,IRF7329PBFDKR-ND|IRF7329TRPBF|
|SI4948BEY-T1-E3TR-ND,SI4948BEY-T1-E3CT-ND,SI4948BEY-T1-E3DKR-ND|SI4948BEY-T1-E3|
|FDMA1024NZTR-ND,FDMA1024NZCT-ND,FDMA1024NZDKR-ND|FDMA1024NZ|
|SI4564DY-T1-GE3TR-ND,SI4564DY-T1-GE3CT-ND,SI4564DY-T1-GE3DKR-ND|SI4564DY-T1-GE3|
|SI4288DY-T1-GE3TR-ND,SI4288DY-T1-GE3CT-ND,SI4288DY-T1-GE3DKR-ND|SI4288DY-T1-GE3|
|SI7272DP-T1-GE3TR-ND,SI7272DP-T1-GE3CT-ND,SI7272DP-T1-GE3DKR-ND|SI7272DP-T1-GE3|
|497-17309-2-ND,497-17309-1-ND,497-17309-6-ND|STS8DN6LF6AG|
|SI7212DN-T1-GE3TR-ND,SI7212DN-T1-GE3CT-ND,SI7212DN-T1-GE3DKR-ND|SI7212DN-T1-GE3|
|448-BSC112N06LDATMA1TR-ND,448-BSC112N06LDATMA1CT-ND,448-BSC112N06LDATMA1DKR-ND|BSC112N06LDATMA1|
|BSC0921NDIATMA1TR-ND,BSC0921NDIATMA1CT-ND,BSC0921NDIATMA1DKR-ND|BSC0921NDIATMA1|
|IRF7351TRPBFTR-ND,IRF7351TRPBFCT-ND,IRF7351TRPBFDKR-ND|IRF7351TRPBF|
|IPG20N10S4L22ATMA1TR-ND,IPG20N10S4L22ATMA1CT-ND,IPG20N10S4L22ATMA1DKR-ND|IPG20N10S4L22ATMA1|
|FDMQ8203TR-ND,FDMQ8203CT-ND,FDMQ8203DKR-ND|FDMQ8203|
|SQ4920EY-T1_GE3TR-ND,SQ4920EY-T1_GE3CT-ND,SQ4920EY-T1_GE3DKR-ND|SQ4920EY-T1_GE3|
|ZXMHC3A01T8TR-ND,ZXMHC3A01T8CT-ND,ZXMHC3A01T8DKR-ND|ZXMHC3A01T8TA|
|NDS9945TR-ND,NDS9945CT-ND|NDS9945|
|FDS3890TR-ND,FDS3890CT-ND,FDS3890DKR-ND|FDS3890|
|448-BSG0810NDIATMA1TR-ND,448-BSG0810NDIATMA1CT-ND,448-BSG0810NDIATMA1DKR-ND|BSG0810NDIATMA1|
|BSG0811NDATMA1TR-ND,BSG0811NDATMA1CT-ND,BSG0811NDATMA1DKR-ND|BSG0811NDATMA1|
|296-27532-2-ND,296-27532-1-ND,296-27532-6-ND|CSD86350Q5D|
|FDS89141TR-ND,FDS89141CT-ND,FDS89141DKR-ND|FDS89141|
|SI7956DP-T1-GE3TR-ND,SI7956DP-T1-GE3CT-ND,SI7956DP-T1-GE3DKR-ND|SI7956DP-T1-GE3|
|FDMQ86530LTR-ND,FDMQ86530LCT-ND,FDMQ86530LDKR-ND|FDMQ86530L|
|31-DMN2991UDR4-7RTR-ND,31-DMN2991UDR4-7RCT-ND,31-DMN2991UDR4-7RDKR-ND|DMN2991UDR4-7R|
|353-BSS138AKDWHE3-TPTR-ND,353-BSS138AKDWHE3-TPCT-ND,353-BSS138AKDWHE3-TPDKR-ND|BSS138AKDWHE3-TP|
|DMN63D8LDW-7TR-ND,DMN63D8LDW-7CT-ND,DMN63D8LDW-7DKR-ND|DMN63D8LDW-7|
|SSM6N7002BFELMTR-ND,SSM6N7002BFELMCT-ND,SSM6N7002BFELMDKR-ND|SSM6N7002BFE,LM|
|31-DMN63D8LDW-13TR-ND,31-DMN63D8LDW-13CT-ND,31-DMN63D8LDW-13DKR-ND|DMN63D8LDW-13|
|NTJD5121NT1GOSTR-ND,NTJD5121NT1GOSCT-ND,NTJD5121NT1GOSDKR-ND|NTJD5121NT1G|
|DMN63D8LV-7DITR-ND,DMN63D8LV-7DICT-ND,DMN63D8LV-7DIDKR-ND|DMN63D8LV-7|
|1727-1291-2-ND,1727-1291-1-ND,1727-1291-6-ND|NX7002AKS,115|
|DMN53D0LDW-13DITR-ND,DMN53D0LDW-13DICT-ND,DMN53D0LDW-13DIDKR-ND|DMN53D0LDW-13|
|SSM6N15AFULFTR-ND,SSM6N15AFULFCT-ND,SSM6N15AFULFDKR-ND|SSM6N15AFU,LF|
|DMN53D0LDW-7DITR-ND,DMN53D0LDW-7DICT-ND,DMN53D0LDW-7DIDKR-ND|DMN53D0LDW-7|
|DMN65D8LDW-7DITR-ND,DMN65D8LDW-7DICT-ND,DMN65D8LDW-7DIDKR-ND|DMN65D8LDW-7|
|SSM6N35AFELFTR-ND,SSM6N35AFELFCT-ND,SSM6N35AFELFDKR-ND|SSM6N35AFE,LF|
|DMC2400UV-7DITR-ND,DMC2400UV-7DICT-ND,DMC2400UV-7DIDKR-ND|DMC2400UV-7|
|1727-1286-2-ND,1727-1286-1-ND,1727-1286-6-ND|NX3020NAKS,115|
|SSM6P35AFELFTR-ND,SSM6P35AFELFCT-ND,SSM6P35AFELFDKR-ND|SSM6P35AFE,LF|
|1727-6480-2-ND,1727-6480-1-ND,1727-6480-6-ND|BSS84AKS,115|
|1727-4786-2-ND,1727-4786-1-ND,1727-4786-6-ND|2N7002BKS,115|
|SSM6L36FELMTR-ND,SSM6L36FELMCT-ND,SSM6L36FELMDKR-ND|SSM6L36FE,LM|
|SSM6N43FULFTR-ND,SSM6N43FULFCT-ND,SSM6N43FULFDKR-ND|SSM6N43FU,LF|
|SSM6N56FELMTR-ND,SSM6N56FELMCT-ND,SSM6N56FELMDKR-ND|SSM6N56FE,LM|
|DMN3190LDW-13DITR-ND,DMN3190LDW-13DICT-ND,DMN3190LDW-13DIDKR-ND|DMN3190LDW-13|
|DMN3190LDW-7DITR-ND,DMN3190LDW-7DICT-ND,DMN3190LDW-7DIDKR-ND|DMN3190LDW-7|
|1727-1221-2-ND,1727-1221-1-ND,1727-1221-6-ND|NX3008NBKS,115|
|1727-6478-2-ND,1727-6478-1-ND,1727-6478-6-ND|BSS138BKS,115|
|1727-1282-2-ND,1727-1282-1-ND,1727-1282-6-ND|NX3008PBKS,115|
|1727-1278-2-ND,1727-1278-1-ND,1727-1278-6-ND|NX3008CBKS,115|
|NTJD5121NT2GOSTR-ND,NTJD5121NT2GOSCT-ND,NTJD5121NT2GOSDKR-ND|NTJD5121NT2G|
|BSD223PH6327XTSA1TR-ND,BSD223PH6327XTSA1CT-ND,BSD223PH6327XTSA1DKR-ND|BSD223PH6327XTSA1|
|DMN32D2LDF-7DITR-ND,DMN32D2LDF-7DICT-ND,DMN32D2LDF-7DIDKR-ND|DMN32D2LDF-7|
|NTZD5110NT1GOSTR-ND,NTZD5110NT1GOSCT-ND,NTZD5110NT1GOSDKR-ND|NTZD5110NT1G|
|NTZD3155CT2GOSTR-ND,NTZD3155CT2GOSCT-ND,NTZD3155CT2GOSDKR-ND|NTZD3155CT2G|
|SSM6P15FE(TE85LF)TR-ND,SSM6P15FE(TE85LF)CT-ND,SSM6P15FE(TE85LF)DKR-ND|SSM6P15FE(TE85L,F)|
|DMG1016V-7DITR-ND,DMG1016V-7DICT-ND,DMG1016V-7DIDKR-ND|DMG1016V-7|
|DMN2400UV-7DITR-ND,DMN2400UV-7DICT-ND,DMN2400UV-7DIDKR-ND|DMN2400UV-7|
|BSD235CH6327XTSA1TR-ND,BSD235CH6327XTSA1CT-ND,BSD235CH6327XTSA1DKR-ND|BSD235CH6327XTSA1|
|DMP3085LSD-13DITR-ND,DMP3085LSD-13DICT-ND,DMP3085LSD-13DIDKR-ND|DMP3085LSD-13|
|UM6K31NTNTR-ND,UM6K31NTNCT-ND,UM6K31NTNDKR-ND|UM6K31NTN|
|BSS84DW-FDITR-ND,BSS84DW-FDICT-ND,BSS84DW-FDIDKR-ND|BSS84DW-7-F|
|1727-1354-2-ND,1727-1354-1-ND,1727-1354-6-ND|PMGD290UCEAX|
|DMG1023UV-7DITR-ND,DMG1023UV-7DICT-ND,DMG1023UV-7DIDKR-ND|DMG1023UV-7|
|DMG1026UV-7DITR-ND,DMG1026UV-7DICT-ND,DMG1026UV-7DIDKR-ND|DMG1026UV-7|
|DMG1024UV-7DITR-ND,DMG1024UV-7DICT-ND,DMG1024UV-7DIDKR-ND|DMG1024UV-7|
|DMC2990UDJ-7DITR-ND,DMC2990UDJ-7DICT-ND,DMC2990UDJ-7DIDKR-ND|DMC2990UDJ-7|
|DMN2990UDJ-7DITR-ND,DMN2990UDJ-7DICT-ND,DMN2990UDJ-7DIDKR-ND|DMN2990UDJ-7|
|NTJD4158CT1GOSTR-ND,NTJD4158CT1GOSCT-ND,NTJD4158CT1GOSDKR-ND|NTJD4158CT1G|
|DMP2004VKDITR-ND,DMP2004VKDICT-ND,DMP2004VKDIDKR-ND|DMP2004VK-7|
|SI1902CDL-T1-GE3TR-ND,SI1902CDL-T1-GE3CT-ND,SI1902CDL-T1-GE3DKR-ND|SI1902CDL-T1-GE3|
|SSM6N40TULFTR-ND,SSM6N40TULFCT-ND,SSM6N40TULFDKR-ND|SSM6N40TU,LF|
|SSM6L40TULFTR-ND,SSM6L40TULFCT-ND,SSM6L40TULFDKR-ND|SSM6L40TU,LF|
|264-SSM6L39TU,LFTR-ND,264-SSM6L39TU,LFCT-ND,264-SSM6L39TU,LFDKR-ND|SSM6L39TU,LF|
|NTJD4105CT1GOSTR-ND,NTJD4105CT1GOSCT-ND,NTJD4105CT1GOSDKR-ND|NTJD4105CT1G|
|DMN601DWKDITR-ND,DMN601DWKDICT-ND,DMN601DWKDIDKR-ND|DMN601DWK-7|
|DMC2004DWKDITR-ND,DMC2004DWKDICT-ND,DMC2004DWKDIDKR-ND|DMC2004DWK-7|
|EM6K6T2RTR-ND,EM6K6T2RCT-ND,EM6K6T2RDKR-ND|EM6K6T2R|
|846-EM6K33T2RTR-ND,846-EM6K33T2RCT-ND,846-EM6K33T2RDKR-ND|EM6K33T2R|
|DMN2019UTS-13DITR-ND,DMN2019UTS-13DICT-ND,DMN2019UTS-13DIDKR-ND|DMN2019UTS-13|
|SSM6N62TULFTR-ND,SSM6N62TULFCT-ND,SSM6N62TULFDKR-ND|SSM6N62TU,LF|
|NTUD3169CZT5GOSTR-ND,NTUD3169CZT5GOSCT-ND,NTUD3169CZT5GOSDKR-ND|NTUD3169CZT5G|
|SI1922EDH-T1-GE3TR-ND,SI1922EDH-T1-GE3CT-ND,SI1922EDH-T1-GE3DKR-ND|SI1922EDH-T1-GE3|
|SI1967DH-T1-GE3TR-ND,SI1967DH-T1-GE3CT-ND,SI1967DH-T1-GE3DKR-ND|SI1967DH-T1-GE3|
|DMN2029USD-13DITR-ND,DMN2029USD-13DICT-ND,DMN2029USD-13DIDKR-ND|DMN2029USD-13|
|EM6K7T2RTR-ND,EM6K7T2RCT-ND,EM6K7T2RDKR-ND|EM6K7T2R|
|1727-1328-2-ND,1727-1328-1-ND,1727-1328-6-ND|PMDPB30XN,115|
|DMG9933USD-13DITR-ND,DMG9933USD-13DICT-ND,DMG9933USD-13DIDKR-ND|DMG9933USD-13|
|31-BSS8402DWQ-7TR-ND,31-BSS8402DWQ-7CT-ND,31-BSS8402DWQ-7DKR-ND|BSS8402DWQ-7|
|SSM6N815RLFTR-ND,SSM6N815RLFCT-ND,SSM6N815RLFDKR-ND|SSM6N815R,LF|
|1727-1237-2-ND,1727-1237-1-ND,1727-1237-6-ND|PMDPB58UPE,115|
|2N7002VTR-ND,2N7002VCT-ND,2N7002VDKR-ND|2N7002V|
|EM6J1T2RTR-ND,EM6J1T2RCT-ND,EM6J1T2RDKR-ND|EM6J1T2R|
|DMP2160UFDB-7DITR-ND,DMP2160UFDB-7DICT-ND,DMP2160UFDB-7DIDKR-ND|DMP2160UFDB-7|
|DMG9926USD-13DITR-ND,DMG9926USD-13DICT-ND,DMG9926USD-13DIDKR-ND|DMG9926USD-13|
|DMC3032LSD-13DITR-ND,DMC3032LSD-13DICT-ND,DMC3032LSD-13DIDKR-ND|DMC3032LSD-13|
|FDC6303NTR-ND,FDC6303NCT-ND,FDC6303NDKR-ND|FDC6303N|
|NDC7001CTR-ND,NDC7001CCT-ND,NDC7001CDKR-ND|NDC7001C|
|264-SSM6P816RLFTR-ND,264-SSM6P816RLFCT-ND,264-SSM6P816RLFDKR-ND|SSM6P816R,LF|
|785-1586-2-ND,785-1586-1-ND,785-1586-6-ND|AON7804|
|DMN61D8LVTQ-7DITR-ND,DMN61D8LVTQ-7DICT-ND,DMN61D8LVTQ-7DIDKR-ND|DMN61D8LVTQ-7|
|DMN61D8LVT-7DITR-ND,DMN61D8LVT-7DICT-ND,DMN61D8LVT-7DIDKR-ND|DMN61D8LVT-7|
|31-DMN61D8LVT-13TR-ND,31-DMN61D8LVT-13CT-ND,31-DMN61D8LVT-13DKR-ND|DMN61D8LVT-13|
|BSL316CH6327XTSA1TR-ND,BSL316CH6327XTSA1CT-ND,BSL316CH6327XTSA1DKR-ND|BSL316CH6327XTSA1|
|SI1029X-T1-GE3TR-ND,SI1029X-T1-GE3CT-ND,SI1029X-T1-GE3DKR-ND|SI1029X-T1-GE3|
|SI1965DH-T1-GE3TR-ND,SI1965DH-T1-GE3CT-ND,SI1965DH-T1-GE3DKR-ND|SI1965DH-T1-GE3|
|DMN2041LSD-13DITR-ND,DMN2041LSD-13DICT-ND,DMN2041LSD-13DIDKR-ND|DMN2041LSD-13|
|EM6K31T2RTR-ND,EM6K31T2RCT-ND,EM6K31T2RDKR-ND|EM6K31T2R|
|DMN3018SSD-13DITR-ND,DMN3018SSD-13DICT-ND,DMN3018SSD-13DIDKR-ND|DMN3018SSD-13|
|NDC7003PTR-ND,NDC7003PCT-ND,NDC7003PDKR-ND|NDC7003P|
|DMN6070SSD-13DITR-ND,DMN6070SSD-13DICT-ND,DMN6070SSD-13DIDKR-ND|DMN6070SSD-13|
|DMC3028LSD-13DITR-ND,DMC3028LSD-13DICT-ND,DMC3028LSD-13DIDKR-ND|DMC3028LSD-13|
|NTGD3148NT1GOSTR-ND,NTGD3148NT1GOSCT-ND,NTGD3148NT1GOSDKR-ND|NTGD3148NT1G|
|296-38339-2-ND,296-38339-1-ND,296-38339-6-ND|CSD75208W1015|
|SIA527DJ-T1-GE3TR-ND,SIA527DJ-T1-GE3CT-ND,SIA527DJ-T1-GE3DKR-ND|SIA527DJ-T1-GE3|
|SI3585CDV-T1-GE3TR-ND,SI3585CDV-T1-GE3CT-ND,SI3585CDV-T1-GE3DKR-ND|SI3585CDV-T1-GE3|
|BSL215CH6327XTSA1TR-ND,BSL215CH6327XTSA1CT-ND,BSL215CH6327XTSA1DKR-ND|BSL215CH6327XTSA1|
|785-1775-2-ND,785-1775-1-ND,785-1775-6-ND|AON7810|
|DMN6040SSD-13DITR-ND,DMN6040SSD-13DICT-ND,DMN6040SSD-13DIDKR-ND|DMN6040SSD-13|
|785-1404-2-ND,785-1404-1-ND,785-1404-6-ND|AON7611|
|785-1570-2-ND,785-1570-1-ND,785-1570-6-ND|AON3611|
|DMN2016UTS-13DITR-ND,DMN2016UTS-13DICT-ND,DMN2016UTS-13DIDKR-ND|DMN2016UTS-13|
|DMP2035UTS-13DITR-ND,DMP2035UTS-13DICT-ND,DMP2035UTS-13DIDKR-ND|DMP2035UTS-13|
|SIA519EDJ-T1-GE3TR-ND,SIA519EDJ-T1-GE3CT-ND,SIA519EDJ-T1-GE3DKR-ND|SIA519EDJ-T1-GE3|
|SIA906EDJ-T1-GE3TR-ND,SIA906EDJ-T1-GE3CT-ND,SIA906EDJ-T1-GE3DKR-ND|SIA906EDJ-T1-GE3|
|BSL308PEH6327XTSA1TR-ND,BSL308PEH6327XTSA1CT-ND,BSL308PEH6327XTSA1DKR-ND|BSL308PEH6327XTSA1|
|SIA517DJ-T1-GE3TR-ND,SIA517DJ-T1-GE3CT-ND,SIA517DJ-T1-GE3DKR-ND|SIA517DJ-T1-GE3|
|BSL308CH6327XTSA1TR-ND,BSL308CH6327XTSA1CT-ND,BSL308CH6327XTSA1DKR-ND|BSL308CH6327XTSA1|
|FDC6306PTR-ND,FDC6306PCT-ND,FDC6306PDKR-ND|FDC6306P|
|DMN3024LSD-13DITR-ND,DMN3024LSD-13DICT-ND,DMN3024LSD-13DIDKR-ND|DMN3024LSD-13|
|SIA923AEDJ-T1-GE3TR-ND,SIA923AEDJ-T1-GE3CT-ND,SIA923AEDJ-T1-GE3DKR-ND|SIA923AEDJ-T1-GE3|
|1514-CMLDM7585TRPBFREETR-ND,1514-CMLDM7585TRPBFREECT-ND,1514-CMLDM7585TRPBFREEDKR-ND|CMLDM7585 TR PBFREE|
|TSM2537CQRFGTR-ND,TSM2537CQRFGCT-ND,TSM2537CQRFGDKR-ND|TSM2537CQ RFG|
|US6M11TR-ND,US6M11CT-ND,US6M11DKR-ND|US6M11TR|
|296-40010-2-ND,296-40010-1-ND,296-40010-6-ND|CSD85301Q2|
|QS5K2TR-ND,QS5K2CT-ND,QS5K2DKR-ND|QS5K2TR|
|US6K1TR-ND,US6K1CT-ND,US6K1DKR-ND|US6K1TR|
|DMG6898LSD-13DITR-ND,DMG6898LSD-13DICT-ND,DMG6898LSD-13DIDKR-ND|DMG6898LSD-13|
|846-QS6K1FRATR-ND,846-QS6K1FRACT-ND,846-QS6K1FRADKR-ND|QS6K1FRATR|
|ECH8697R-TL-WOSTR-ND,ECH8697R-TL-WOSCT-ND,ECH8697R-TL-WOSDKR-ND|ECH8697R-TL-W|
|FDC6310PFSTR-ND,FDC6310PFSCT-ND,FDC6310PFSDKR-ND|FDC6310P|
|SI9933CDY-T1-GE3TR-ND,SI9933CDY-T1-GE3CT-ND,SI9933CDY-T1-GE3DKR-ND|SI9933CDY-T1-GE3|
|FDC6420CTR-ND,FDC6420CCT-ND,FDC6420CDKR-ND|FDC6420C|
|SIA921EDJ-T1-GE3TR-ND,SIA921EDJ-T1-GE3CT-ND,SIA921EDJ-T1-GE3DKR-ND|SIA921EDJ-T1-GE3|
|QS6J11TR-ND,QS6J11CT-ND,QS6J11DKR-ND|QS6J11TR|
|846-QS6J1TR-ND,846-QS6J1CT-ND,846-QS6J1DKR-ND|QS6J1TR|
|FDS9945TR-ND,FDS9945CT-ND,FDS9945DKR-ND|FDS9945|
|ECH8657-TL-HOSTR-ND,ECH8657-TL-HOSCT-ND,ECH8657-TL-HOSDKR-ND|ECH8657-TL-H|
|DMC6040SSD-13DITR-ND,DMC6040SSD-13DICT-ND,DMC6040SSD-13DIDKR-ND|DMC6040SSD-13|
|SI5936DU-T1-GE3TR-ND,SI5936DU-T1-GE3CT-ND,SI5936DU-T1-GE3DKR-ND|SI5936DU-T1-GE3|
|296-40008-2-ND,296-40008-1-ND,296-40008-6-ND|CSD75207W15|
|SI4214DDY-T1-GE3TR-ND,SI4214DDY-T1-GE3CT-ND,SI4214DDY-T1-GE3DKR-ND|SI4214DDY-T1-GE3|
|QS6K1TR-ND,QS6K1CT-ND,QS6K1DKR-ND|QS6K1TR|
|DMP3098LSD-13DITR-ND,DMP3098LSD-13DICT-ND,DMP3098LSD-13DIDKR-ND|DMP3098LSD-13|
|DMP4047SSD-13DITR-ND,DMP4047SSD-13DICT-ND,DMP4047SSD-13DIDKR-ND|DMP4047SSD-13|
|IRLHS6276TRPBFTR-ND,IRLHS6276TRPBFCT-ND,IRLHS6276TRPBFDKR-ND|IRLHS6276TRPBF|
|NDS9948TR-ND,NDS9948CT-ND,NDS9948DKR-ND|NDS9948|
|1514-CMLDM8005TRPBFREETR-ND,1514-CMLDM8005TRPBFREECT-ND,1514-CMLDM8005TRPBFREEDKR-ND|CMLDM8005 TR PBFREE|
|264-SSM6N813RLXHFTR-ND,264-SSM6N813RLXHFCT-ND,264-SSM6N813RLXHFDKR-ND|SSM6N813R,LXHF|
|ECH8695R-TL-WOSTR-ND,ECH8695R-TL-WOSCT-ND,ECH8695R-TL-WOSDKR-ND|ECH8695R-TL-W|
|NTMD4N03R2GOSTR-ND,NTMD4N03R2GOSCT-ND,NTMD4N03R2GOSDKR-ND|NTMD4N03R2G|
|FDC6312PTR-ND,FDC6312PCT-ND,FDC6312PDKR-ND|FDC6312P|
|SI4554DY-T1-GE3TR-ND,SI4554DY-T1-GE3CT-ND,SI4554DY-T1-GE3DKR-ND|SI4554DY-T1-GE3|
|IRF9952PBFTR-ND,IRF9952PBFCT-ND,IRF9952PBFDKR-ND|IRF9952TRPBF|
|SI5515CDC-T1-GE3TR-ND,SI5515CDC-T1-GE3CT-ND,SI5515CDC-T1-GE3DKR-ND|SI5515CDC-T1-GE3|
|FDS6912ATR-ND,FDS6912ACT-ND,FDS6912ADKR-ND|FDS6912A|
|SI3552DV-T1-GE3TR-ND,SI3552DV-T1-GE3CT-ND,SI3552DV-T1-GE3DKR-ND|SI3552DV-T1-GE3|
|296-40011-2-ND,296-40011-1-ND,296-40011-6-ND|CSD87381P|
|488-NTLJD4116NT1GTR-ND,488-NTLJD4116NT1GCT-ND,488-NTLJD4116NT1GDKR-ND|NTLJD4116NT1G|
|296-40013-2-ND,296-40013-1-ND,296-40013-6-ND,2156-CSD87501L-ND|CSD87501L|
|NTLJD3119CTBGOSTR-ND,NTLJD3119CTBGOSCT-ND,NTLJD3119CTBGOSDKR-ND|NTLJD3119CTBG|
|FDMA1029PZTR-ND,FDMA1029PZCT-ND,FDMA1029PZDKR-ND|FDMA1029PZ|
|NTMD6N02R2GOSTR-ND,NTMD6N02R2GOSCT-ND,NTMD6N02R2GOSDKR-ND|NTMD6N02R2G|
|ZXMN6A11DN8TR-ND,ZXMN6A11DN8CT-ND|ZXMN6A11DN8TA|
|SI7232DN-T1-GE3TR-ND,SI7232DN-T1-GE3CT-ND,SI7232DN-T1-GE3DKR-ND|SI7232DN-T1-GE3|
|SI4599DY-T1-GE3TR-ND,SI4599DY-T1-GE3CT-ND,SI4599DY-T1-GE3DKR-ND|SI4599DY-T1-GE3|
|BSO220N03MDGXUMA1TR-ND,BSO220N03MDGXUMA1CT-ND,BSO220N03MDGXUMA1DKR-ND|BSO220N03MDGXUMA1|
|ZXMN10A08DN8TATR-ND,ZXMN10A08DN8TACT-ND,ZXMN10A08DN8TADKR-ND|ZXMN10A08DN8TA|
|DMN6066SSD-13TR-ND,DMN6066SSD-13CT-ND,DMN6066SSD-13DKR-ND|DMN6066SSD-13|
|DMC4028SSD-13DITR-ND,DMC4028SSD-13DICT-ND,DMC4028SSD-13DIDKR-ND|DMC4028SSD-13|
|IRF9362TRPBFTR-ND,IRF9362TRPBFCT-ND,IRF9362TRPBFDKR-ND|IRF9362TRPBF|
|785-1058-2-ND,785-1058-1-ND,785-1058-6-ND|AO4813|
|FDS9934CTR-ND,FDS9934CCT-ND,FDS9934CDKR-ND|FDS9934C|
|31-DMHC3025LSDQ-13TR-ND,31-DMHC3025LSDQ-13CT-ND,31-DMHC3025LSDQ-13DKR-ND|DMHC3025LSDQ-13|
|SI6954ADQ-T1-GE3TR-ND,SI6954ADQ-T1-GE3CT-ND,SI6954ADQ-T1-GE3DKR-ND|SI6954ADQ-T1-GE3|
|IRL6372TRPBFTR-ND,IRL6372TRPBFCT-ND,IRL6372TRPBFDKR-ND|IRL6372TRPBF|
|296-29660-2-ND,296-29660-1-ND,296-29660-6-ND|CSD87330Q3D|
|846-QS8K21TR-ND,846-QS8K21CT-ND,846-QS8K21DKR-ND|QS8K21TR|
|785-1509-2-ND,785-1509-1-ND,785-1509-6-ND|AON7934|
|ZXMC3A17DN8TR-ND,ZXMC3A17DN8CT-ND,ZXMC3A17DN8DKR-ND|ZXMC3A17DN8TA|
|ZXMC10A816N8DITR-ND,ZXMC10A816N8DICT-ND,ZXMC10A816N8DIDKR-ND|ZXMC10A816N8TC|
|785-1499-2-ND,785-1499-1-ND,785-1499-6-ND|AON6816|
|1727-1898-2-ND,1727-1898-1-ND,1727-1898-6-ND|BUK9K134-100EX|
|ECH8667-TL-HOSTR-ND,ECH8667-TL-HOSCT-ND,ECH8667-TL-HOSDKR-ND|ECH8667-TL-H|
|DMN4026SSD-13DITR-ND,DMN4026SSD-13DICT-ND,DMN4026SSD-13DIDKR-ND|DMN4026SSD-13|
|NTHD3100CT1GOSTR-ND,NTHD3100CT1GOSCT-ND,NTHD3100CT1GOSDKR-ND|NTHD3100CT1G|
|IRF7316PBFTR-ND,IRF7316PBFCT-ND,IRF7316PBFDKR-ND|IRF7316TRPBF|
|ZXMHC3A01N8DITR-ND,ZXMHC3A01N8DICT-ND,ZXMHC3A01N8DIDKR-ND|ZXMHC3A01N8TC|
|DMC4015SSD-13DITR-ND,DMC4015SSD-13DICT-ND,DMC4015SSD-13DIDKR-ND|DMC4015SSD-13|
|ZXMHC6A07N8DITR-ND,ZXMHC6A07N8DICT-ND,ZXMHC6A07N8DIDKR-ND|ZXMHC6A07N8TC|
|FDS9958TR-ND,FDS9958CT-ND,FDS9958DKR-ND|FDS9958|
|1727-7269-2-ND,1727-7269-1-ND,1727-7269-6-ND|BUK9K18-40E,115|
|SQ9945BEY-T1_GE3TR-ND,SQ9945BEY-T1_GE3CT-ND,SQ9945BEY-T1_GE3DKR-ND|SQ9945BEY-T1_GE3|
|QS8J4TR-ND,QS8J4CT-ND,QS8J4DKR-ND|QS8J4TR|
|785-1792-2-ND,785-1792-1-ND,785-1792-6-ND|AOSD62666E|
|785-1203-2-ND,785-1203-1-ND,785-1203-6-ND|AO4611|
|296-38668-2-ND,296-38668-1-ND,296-38668-6-ND|CSD85301Q2T|
|FDMC8200STR-ND,FDMC8200SCT-ND,FDMC8200SDKR-ND|FDMC8200S|
|FDS6898AZTR-ND,FDS6898AZCT-ND,FDS6898AZDKR-ND|FDS6898AZ|
|NTMD6P02R2GOSTR-ND,NTMD6P02R2GOSCT-ND,NTMD6P02R2GOSDKR-ND|NTMD6P02R2G|
|296-37187-2-ND,296-37187-1-ND,296-37187-6-ND,2156-CSD85312Q3E-ND|CSD85312Q3E|
|SI9926CDY-T1-E3TR-ND,SI9926CDY-T1-E3CT-ND,SI9926CDY-T1-E3DKR-ND|SI9926CDY-T1-E3|
|SI4948BEY-T1-GE3TR-ND,SI4948BEY-T1-GE3CT-ND,SI4948BEY-T1-GE3DKR-ND|SI4948BEY-T1-GE3|
|FDMB3800NTR-ND,FDMB3800NCT-ND,FDMB3800NDKR-ND|FDMB3800N|
|SI6913DQ-T1-GE3TR-ND,SI6913DQ-T1-GE3CT-ND,SI6913DQ-T1-GE3DKR-ND|SI6913DQ-T1-GE3|
|IPG20N04S4L08ATMA1TR-ND,IPG20N04S4L08ATMA1CT-ND,IPG20N04S4L08ATMA1DKR-ND|IPG20N04S4L08ATMA1|
|448-IAUC60N04S6L045HATMA1TR-ND,448-IAUC60N04S6L045HATMA1CT-ND,448-IAUC60N04S6L045HATMA1DKR-ND|IAUC60N04S6L045HATMA1|
|SH8J62TB1TR-ND,SH8J62TB1CT-ND,SH8J62TB1DKR-ND|SH8J62TB1|
|SI4202DY-T1-GE3TR-ND,SI4202DY-T1-GE3CT-ND,SI4202DY-T1-GE3DKR-ND|SI4202DY-T1-GE3|
|IPG20N10S4L35ATMA1TR-ND,IPG20N10S4L35ATMA1CT-ND,IPG20N10S4L35ATMA1DKR-ND|IPG20N10S4L35ATMA1|
|SI4932DY-T1-GE3TR-ND,SI4932DY-T1-GE3CT-ND,SI4932DY-T1-GE3DKR-ND|SI4932DY-T1-GE3|
|QS8M51TR-ND,QS8M51CT-ND,QS8M51DKR-ND|QS8M51TR|
|448-BSZ215CHXTMA1TR-ND,448-BSZ215CHXTMA1CT-ND,448-BSZ215CHXTMA1DKR-ND|BSZ215CHXTMA1|
|IRF7324PBFTR-ND,IRF7324PBFCT-ND,IRF7324PBFDKR-ND|IRF7324TRPBF|
|FDS6975TR-ND,FDS6975CT-ND,FDS6975DKR-ND|FDS6975|
|FDS6890ATR-ND,FDS6890ACT-ND,FDS6890ADKR-ND|FDS6890A|
|ECH8690-TL-HOSTR-ND,ECH8690-TL-HOSCT-ND,ECH8690-TL-HOSDKR-ND|ECH8690-TL-H|
|IPG20N04S4L07ATMA1TR-ND,IPG20N04S4L07ATMA1CT-ND,IPG20N04S4L07ATMA1DKR-ND|IPG20N04S4L07ATMA1|
|SI7998DP-T1-GE3TR-ND,SI7998DP-T1-GE3CT-ND,SI7998DP-T1-GE3DKR-ND|SI7998DP-T1-GE3|
|448-BSC072N04LDATMA1TR-ND,448-BSC072N04LDATMA1CT-ND,448-BSC072N04LDATMA1DKR-ND|BSC072N04LDATMA1|
|296-28318-2-ND,296-28318-1-ND,296-28318-6-ND|CSD87350Q5D|
|SQ4284EY-T1_GE3TR-ND,SQ4284EY-T1_GE3CT-ND,SQ4284EY-T1_GE3DKR-ND|SQ4284EY-T1_GE3|
|SI4816BDY-T1-E3TR-ND,SI4816BDY-T1-E3CT-ND,SI4816BDY-T1-E3DKR-ND|SI4816BDY-T1-E3|
|IPG20N10S4L22AATMA1TR-ND,IPG20N10S4L22AATMA1CT-ND,IPG20N10S4L22AATMA1DKR-ND|IPG20N10S4L22AATMA1|
|SIZ918DT-T1-GE3TR-ND,SIZ918DT-T1-GE3CT-ND,SIZ918DT-T1-GE3DKR-ND|SIZ918DT-T1-GE3|
|ZXMHC6A07T8TR-ND,ZXMHC6A07T8CT-ND|ZXMHC6A07T8TA|
|ZXMN3A04DN8TR-ND,ZXMN3A04DN8CT-ND,ZXMN3A04DN8DKR-ND|ZXMN3A04DN8TA|
|488-HUFA76407DK8T-F085TR-ND,488-HUFA76407DK8T-F085CT-ND,488-HUFA76407DK8T-F085DKR-ND|HUFA76407DK8T-F085|
|FDMC7208STR-ND,FDMC7208SCT-ND,FDMC7208SDKR-ND|FDMC7208S|
|1727-7270-2-ND,1727-7270-1-ND,1727-7270-6-ND|BUK9K29-100E,115|
|ZXMN6A09DN8TR-ND,ZXMN6A09DN8CT-ND,ZXMN6A09DN8DKR-ND|ZXMN6A09DN8TA|
|497-3226-2-ND,497-3226-1-ND,497-3226-6-ND|STS4DNF60L|
|FDMC89521LTR-ND,FDMC89521LCT-ND,FDMC89521LDKR-ND|FDMC89521L|
|497-13168-2-ND,497-13168-1-ND,497-13168-6-ND|STL8DN10LF3|
|SI7252DP-T1-GE3TR-ND,SI7252DP-T1-GE3CT-ND,SI7252DP-T1-GE3DKR-ND|SI7252DP-T1-GE3|
|SQJ960EP-T1_GE3TR-ND,SQJ960EP-T1_GE3CT-ND,SQJ960EP-T1_GE3DKR-ND|SQJ960EP-T1_GE3|
|296-28216-2-ND,296-28216-1-ND,296-28216-6-ND|CSD86330Q3D|
|FDPC8013STR-ND,FDPC8013SCT-ND,FDPC8013SDKR-ND|FDPC8013S|
|SI7942DP-T1-GE3TR-ND,SI7942DP-T1-GE3CT-ND,SI7942DP-T1-GE3DKR-ND|SI7942DP-T1-GE3|
|SI7942DP-T1-E3TR-ND,SI7942DP-T1-E3CT-ND,SI7942DP-T1-E3DKR-ND|SI7942DP-T1-E3|
|FDMS8090TR-ND,FDMS8090CT-ND,FDMS8090DKR-ND|FDMS8090|
|SSM6L35FELMTR-ND,SSM6L35FELMCT-ND,SSM6L35FELMDKR-ND|SSM6L35FE,LM|
|1801-TSM2N7002AKDCU6RFGTR-ND,1801-TSM2N7002AKDCU6RFGCT-ND,1801-TSM2N7002AKDCU6RFGDKR-ND|TSM2N7002AKDCU6 RFG|
|1727-2254-2-ND,1727-2254-1-ND,1727-2254-6-ND|NX7002BKXBZ|
|1727-7841-2-ND,1727-7841-1-ND,1727-7841-6-ND|BSS138BKSH|
|353-SI3439KDWA-TPTR-ND,353-SI3439KDWA-TPCT-ND,353-SI3439KDWA-TPDKR-ND|SI3439KDWA-TP|
|DMP56D0UV-7DITR-ND,DMP56D0UV-7DICT-ND,DMP56D0UV-7DIDKR-ND|DMP56D0UV-7|
|EM6K31GT2RTR-ND,EM6K31GT2RCT-ND,EM6K31GT2RDKR-ND|EM6K31GT2R|
|SSM6N36TULFTR-ND,SSM6N36TULFCT-ND,SSM6N36TULFDKR-ND|SSM6N36TU,LF|
|SSM6L36TULFTR-ND,SSM6L36TULFCT-ND,SSM6L36TULFDKR-ND|SSM6L36TU,LF|
|EFC4626R-TROSTR-ND,EFC4626R-TROSCT-ND,EFC4626R-TROSDKR-ND|EFC4626R-TR|
|UM6K1NTNTR-ND,UM6K1NTNCT-ND,UM6K1NTNDKR-ND|UM6K1NTN|
|488-EFC4627R-TR-ND,488-EFC4627R-TRCT-ND,488-EFC4627R-TRDKR-ND|EFC4627R-TR|
|NTJD4105CT2GOSTR-ND,NTJD4105CT2GOSCT-ND,NTJD4105CT2GOSDKR-ND|NTJD4105CT2G|
|SSM6P41FE(TE85LF)TR-ND,SSM6P41FE(TE85LF)CT-ND,SSM6P41FE(TE85LF)DKR-ND|SSM6P41FE(TE85L,F)|
|SI1023CX-T1-GE3TR-ND,SI1023CX-T1-GE3CT-ND,SI1023CX-T1-GE3DKR-ND|SI1023CX-T1-GE3|
|SSM6P40TULFTR-ND,SSM6P40TULFCT-ND,SSM6P40TULFDKR-ND|SSM6P40TU,LF|
|DMN2050LFDB-13DITR-ND,DMN2050LFDB-13DICT-ND,DMN2050LFDB-13DIDKR-ND|DMN2050LFDB-13|
|SI1967DH-T1-E3TR-ND,SI1967DH-T1-E3CT-ND,SI1967DH-T1-E3DKR-ND|SI1967DH-T1-E3|
|1727-1330-2-ND,1727-1330-1-ND,1727-1330-6-ND|PMDPB70XPE,115|
|DMC31D5UDJ-7BDITR-ND,DMC31D5UDJ-7BDICT-ND,DMC31D5UDJ-7BDIDKR-ND|DMC31D5UDJ-7B|
|SSM6P49NULFTR-ND,SSM6P49NULFCT-ND,SSM6P49NULFDKR-ND|SSM6P49NU,LF|
|DMC2004LPK-7DITR-ND,DMC2004LPK-7DICT-ND,DMC2004LPK-7DIDKR-ND|DMC2004LPK-7|
|1514-CMRDM3575TRPBFREETR-ND,1514-CMRDM3575TRPBFREECT-ND,1514-CMRDM3575TRPBFREEDKR-ND|CMRDM3575 TR PBFREE|
|DMG1016VQ-7DITR-ND,DMG1016VQ-7DICT-ND,DMG1016VQ-7DIDKR-ND|DMG1016VQ-7|
|UM6J1NTNTR-ND,UM6J1NTNCT-ND,UM6J1NTNDKR-ND|UM6J1NTN|
|742-SI1965DH-T1-E3TR-ND,742-SI1965DH-T1-E3CT-ND,742-SI1965DH-T1-E3DKR-ND|SI1965DH-T1-E3|
|DMN2014LHAB-7DITR-ND,DMN2014LHAB-7DICT-ND,DMN2014LHAB-7DIDKR-ND|DMN2014LHAB-7|
|1514-CMKDM8005TRPBFREETR-ND,1514-CMKDM8005TRPBFREECT-ND,1514-CMKDM8005TRPBFREEDKR-ND|CMKDM8005 TR PBFREE|
|DMC3016LSD-13DITR-ND,DMC3016LSD-13DICT-ND,DMC3016LSD-13DIDKR-ND|DMC3016LSD-13|
|NVJD4401NT1GOSTR-ND,NVJD4401NT1GOSCT-ND,NVJD4401NT1GOSDKR-ND|NVJD4401NT1G|
|SI1900DL-T1-E3TR-ND,SI1900DL-T1-E3CT-ND,SI1900DL-T1-E3DKR-ND|SI1900DL-T1-E3|
|SIA913ADJ-T1-GE3TR-ND,SIA913ADJ-T1-GE3CT-ND,SIA913ADJ-T1-GE3DKR-ND|SIA913ADJ-T1-GE3|
|SI5513CDC-T1-GE3TR-ND,SI5513CDC-T1-GE3CT-ND,SI5513CDC-T1-GE3DKR-ND|SI5513CDC-T1-GE3|
|SI5513CDC-T1-E3TR-ND,SI5513CDC-T1-E3CT-ND,SI5513CDC-T1-E3DKR-ND|SI5513CDC-T1-E3|
|SIA537EDJ-T1-GE3TR-ND,SIA537EDJ-T1-GE3CT-ND,SIA537EDJ-T1-GE3DKR-ND|SIA537EDJ-T1-GE3|
|US6J11TR-ND,US6J11CT-ND,US6J11DKR-ND|US6J11TR|
|DMC3021LSDQ-13DITR-ND,DMC3021LSDQ-13DICT-ND,DMC3021LSDQ-13DIDKR-ND|DMC3021LSDQ-13|
|QH8MA2TCRTR-ND,QH8MA2TCRCT-ND,QH8MA2TCRDKR-ND|QH8MA2TCR|
|QS6M4TR-ND,QS6M4CT-ND,QS6M4DKR-ND|QS6M4TR|
|SI9933CDY-T1-E3TR-ND,SI9933CDY-T1-E3CT-ND,SI9933CDY-T1-E3DKR-ND|SI9933CDY-T1-E3|
|SIA923EDJ-T1-GE3TR-ND,SIA923EDJ-T1-GE3CT-ND,SIA923EDJ-T1-GE3DKR-ND|SIA923EDJ-T1-GE3|
|DMG4822SSD-13DITR-ND,DMG4822SSD-13DICT-ND,DMG4822SSD-13DIDKR-ND|DMG4822SSD-13|
|ECH8693R-TL-WOSTR-ND,ECH8693R-TL-WOSCT-ND,ECH8693R-TL-WOSDKR-ND|ECH8693R-TL-W|
|DMC4050SSD-13TR-ND,DMC4050SSD-13CT-ND,DMC4050SSD-13DKR-ND|DMC4050SSD-13|
|US6K2TR-ND,US6K2CT-ND,US6K2DKR-ND|US6K2TR|
|DMP3056LSD-13DITR-ND,DMP3056LSD-13DICT-ND,DMP3056LSD-13DIDKR-ND|DMP3056LSD-13|
|NTLJD3115PT1GOSTR-ND,NTLJD3115PT1GOSCT-ND,NTLJD3115PT1GOSDKR-ND|NTLJD3115PT1G|
|31-DMN3033LSD-13TR-ND,31-DMN3033LSD-13CT-ND,31-DMN3033LSD-13DKR-ND|DMN3033LSD-13|
|ECH8660-TL-HOSTR-ND,ECH8660-TL-HOSCT-ND,ECH8660-TL-HOSDKR-ND|ECH8660-TL-H|
|IRFHS9351TRPBFTR-ND,IRFHS9351TRPBFCT-ND,IRFHS9351TRPBFDKR-ND|IRFHS9351TRPBF|
|ZXMC3F31DN8TADITR-ND,ZXMC3F31DN8TADICT-ND,ZXMC3F31DN8TADIDKR-ND|ZXMC3F31DN8TA|
|296-38677-2-ND,296-38677-1-ND,296-38677-6-ND,2156-CSD87501LT-ND|CSD87501LT|
|DMG4511SK4-13DITR-ND,DMG4511SK4-13DICT-ND,DMG4511SK4-13DIDKR-ND|DMG4511SK4-13|
|296-35792-2-ND,296-35792-1-ND,296-35792-6-ND|CSD87588N|
|SI5515CDC-T1-E3TR-ND,SI5515CDC-T1-E3CT-ND,SI5515CDC-T1-E3DKR-ND|SI5515CDC-T1-E3|
|FDC6318PTR-ND,FDC6318PCT-ND,FDC6318PDKR-ND|FDC6318P|
|DMC4040SSD-13TR-ND,DMC4040SSD-13CT-ND,DMC4040SSD-13DKR-ND|DMC4040SSD-13|
|FDMA1023PZTR-ND,FDMA1023PZCT-ND,FDMA1023PZDKR-ND|FDMA1023PZ|
|742-SI6954ADQ-T1-E3TR-ND,742-SI6954ADQ-T1-E3CT-ND,742-SI6954ADQ-T1-E3DKR-ND|SI6954ADQ-T1-E3|
|SI4228DY-T1-GE3TR-ND,SI4228DY-T1-GE3CT-ND,SI4228DY-T1-GE3DKR-ND|SI4228DY-T1-GE3|
|BSC150N03LDGATMA1TR-ND,BSC150N03LDGATMA1CT-ND,BSC150N03LDGATMA1DKR-ND|BSC150N03LDGATMA1|
|1727-1808-2-ND,1727-1808-1-ND,1727-1808-6-ND|BUK9K25-40EX|
|296-37751-2-ND,296-37751-1-ND,296-37751-6-ND|CSD87381PT|
|296-43692-2-ND,296-43692-1-ND,296-43692-6-ND|CSD87502Q2T|
|ZXMC3AMCTATR-ND,ZXMC3AMCTACT-ND,ZXMC3AMCTADKR-ND|ZXMC3AMCTA|
|1727-7273-2-ND,1727-7273-1-ND,1727-7273-6-ND|BUK9K52-60E,115|
|448-IPG20N06S2L65ATMA1TR-ND,448-IPG20N06S2L65ATMA1CT-ND,448-IPG20N06S2L65ATMA1DKR-ND|IPG20N06S2L65ATMA1|
|ECH8661-TL-HOSTR-ND,ECH8661-TL-HOSCT-ND,ECH8661-TL-HOSDKR-ND|ECH8661-TL-H|
|ZXMP6A17DN8TR-ND,ZXMP6A17DN8CT-ND,ZXMP6A17DN8DKR-ND|ZXMP6A17DN8TA|
|IPG20N06S2L65AATMA1TR-ND,IPG20N06S2L65AATMA1CT-ND,IPG20N06S2L65AATMA1DKR-ND|IPG20N06S2L65AATMA1|
|296-29161-2-ND,296-29161-1-ND,296-29161-6-ND|CSD87352Q5D|
|SQ4940AEY-T1_GE3TR-ND,SQ4940AEY-T1_GE3CT-ND,SQ4940AEY-T1_GE3DKR-ND|SQ4940AEY-T1_GE3|
|448-BSC0924NDIATMA1TR-ND,448-BSC0924NDIATMA1CT-ND,448-BSC0924NDIATMA1DKR-ND|BSC0924NDIATMA1|
|296-38340-2-ND,296-38340-1-ND,296-38340-6-ND|CSD75208W1015T|
|ZXMN3A06DN8TR-ND,ZXMN3A06DN8CT-ND|ZXMN3A06DN8TA|
|FDMS7608STR-ND,FDMS7608SCT-ND,FDMS7608SDKR-ND|FDMS7608S|
|1727-BUK9K52-60RAXTR-ND,1727-BUK9K52-60RAXCT-ND,1727-BUK9K52-60RAXDKR-ND|BUK9K52-60RAX|
|ZXMC4559DN8TR-ND,ZXMC4559DN8CT-ND,ZXMC4559DN8DKR-ND|ZXMC4559DN8TA|
|FDMC8200TR-ND,FDMC8200CT-ND,FDMC8200DKR-ND|FDMC8200|
|ZXMN6A25DN8TR-ND,ZXMN6A25DN8CT-ND,ZXMN6A25DN8DKR-ND|ZXMN6A25DN8TA|
|448-BSC0923NDIATMA1TR-ND,448-BSC0923NDIATMA1CT-ND,448-BSC0923NDIATMA1DKR-ND|BSC0923NDIATMA1|
|ZXMC3A16DN8TR-ND,ZXMC3A16DN8CT-ND|ZXMC3A16DN8TA|
|ZXMC3A16DN8TCTR-ND,ZXMC3A16DN8TCCT-ND,ZXMC3A16DN8TCDKR-ND|ZXMC3A16DN8TC|
|296-28327-2-ND,296-28327-1-ND,296-28327-6-ND|CSD87351Q5D|
|1727-7272-2-ND,1727-7272-1-ND,1727-7272-6-ND|BUK9K45-100E,115|
|IPG20N06S2L35AATMA1TR-ND,IPG20N06S2L35AATMA1CT-ND,IPG20N06S2L35AATMA1DKR-ND|IPG20N06S2L35AATMA1|
|1727-BUK9V13-40HXTR-ND,1727-BUK9V13-40HXCT-ND,1727-BUK9V13-40HXDKR-ND|BUK9V13-40HX|
|FDMS3604STR-ND,FDMS3604SCT-ND,FDMS3604SDKR-ND|FDMS3604S|
|1727-1807-2-ND,1727-1807-1-ND,1727-1807-6-ND|BUK9K17-60EX|
|448-IPG20N06S4L14AATMA1TR-ND,448-IPG20N06S4L14AATMA1CT-ND,448-IPG20N06S4L14AATMA1DKR-ND|IPG20N06S4L14AATMA1|
|1727-1491-2-ND,1727-1491-1-ND,1727-1491-6-ND|BUK9K8R7-40EX|
|FDMS7620STR-ND,FDMS7620SCT-ND,FDMS7620SDKR-ND|FDMS7620S|
|296-35526-2-ND,296-35526-1-ND,296-35526-6-ND,2156-CSD87312Q3E-ND|CSD87312Q3E|
|FDZ1323NZTR-ND,FDZ1323NZCT-ND,FDZ1323NZDKR-ND|FDZ1323NZ|
|296-37753-2-ND,296-37753-1-ND,296-37753-6-ND|CSD87588NT|
|ZXMP6A18DN8TR-ND,ZXMP6A18DN8CT-ND,ZXMP6A18DN8DKR-ND|ZXMP6A18DN8TA|
|497-15672-2-ND,497-15672-1-ND,497-15672-6-ND|STS5DNF60L|
|SH8M41TB1TR-ND,SH8M41TB1CT-ND,SH8M41TB1DKR-ND|SH8M41TB1|
|BSC0911NDATMA1TR-ND,BSC0911NDATMA1CT-ND,BSC0911NDATMA1DKR-ND|BSC0911NDATMA1|
|1727-2467-2-ND,1727-2467-1-ND,1727-2467-6-ND|BUK9K13-60EX|
|497-10391-2-ND,497-10391-1-ND,497-10391-6-ND|STS8DN3LLH5|
|448-IPG20N06S4L11ATMA2TR-ND,448-IPG20N06S4L11ATMA2CT-ND,448-IPG20N06S4L11ATMA2DKR-ND|IPG20N06S4L11ATMA2|
|1727-7406-2-ND,1727-7406-1-ND,1727-7406-6-ND|BUK9K22-80EX|
|1727-2469-2-ND,1727-2469-1-ND,1727-2469-6-ND|BUK9K5R6-30EX|
|SI7949DP-T1-E3TR-ND,SI7949DP-T1-E3CT-ND,SI7949DP-T1-E3DKR-ND|SI7949DP-T1-E3|
|SI4816BDY-T1-GE3TR-ND,SI4816BDY-T1-GE3CT-ND,SI4816BDY-T1-GE3DKR-ND|SI4816BDY-T1-GE3|
|SI4943CDY-T1-GE3TR-ND,SI4943CDY-T1-GE3CT-ND,SI4943CDY-T1-GE3DKR-ND|SI4943CDY-T1-GE3|
|SI4943CDY-T1-E3TR-ND,SI4943CDY-T1-E3CT-ND,SI4943CDY-T1-E3DKR-ND|SI4943CDY-T1-E3|
|1727-7274-2-ND,1727-7274-1-ND,1727-7274-6-ND|BUK9K6R2-40E,115|
|1727-1897-2-ND,1727-1897-1-ND,1727-1897-6-ND|BUK9K12-60EX|
|497-13167-2-ND,497-13167-1-ND,497-13167-6-ND|STL7DN6LF3|
|1727-2468-2-ND,1727-2468-1-ND,1727-2468-6-ND|BUK9K5R1-30EX|
|SI7922DN-T1-GE3TR-ND,SI7922DN-T1-GE3CT-ND,SI7922DN-T1-GE3DKR-ND|SI7922DN-T1-GE3|
|FDMS3669STR-ND,FDMS3669SCT-ND,FDMS3669SDKR-ND|FDMS3669S|
|FDPC8016STR-ND,FDPC8016SCT-ND,FDPC8016SDKR-ND|FDPC8016S|
|1727-BUK9K13-60RAXTR-ND,1727-BUK9K13-60RAXCT-ND,1727-BUK9K13-60RAXDKR-ND|BUK9K13-60RAX|
|497-13169-2-ND,497-13169-1-ND,497-13169-6-ND|STL8DN6LF3|
|FDMS3660SFSTR-ND,FDMS3660SFSCT-ND,FDMS3660SFSDKR-ND|FDMS3660S|
|296-1352-2-ND,296-1352-1-ND,296-1352-6-ND|TPS1120DR|
|497-12271-2-ND,497-12271-1-ND,497-12271-6-ND|STL66DN3LLH5|
|SH8J66TB1TR-ND,SH8J66TB1CT-ND,SH8J66TB1DKR-ND|SH8J66TB1|
|296-35026-2-ND,296-35026-1-ND,296-35026-6-ND|CSD86360Q5D|
|SI7212DN-T1-E3TR-ND,SI7212DN-T1-E3CT-ND,SI7212DN-T1-E3DKR-ND|SI7212DN-T1-E3|
|296-29661-2-ND,296-29661-1-ND,296-29661-6-ND|CSD87353Q5D|
|1727-2279-2-ND,1727-2279-1-ND,1727-2279-6-ND|PMDXB950UPEZ|
|SSM6P39TULFTR-ND,SSM6P39TULFCT-ND,SSM6P39TULFDKR-ND|SSM6P39TU,LF|
|1514-CMLDM3737TRPBFREETR-ND,1514-CMLDM3737TRPBFREECT-ND,1514-CMLDM3737TRPBFREEDKR-ND|CMLDM3737 TR PBFREE|
|1514-CMLDM3757TRPBFREETR-ND,1514-CMLDM3757TRPBFREECT-ND,1514-CMLDM3757TRPBFREEDKR-ND|CMLDM3757 TR PBFREE|
|DMG8601UFG-7DITR-ND,DMG8601UFG-7DICT-ND,DMG8601UFG-7DIDKR-ND|DMG8601UFG-7|
|1514-CMLDM5757TRPBFREETR-ND,1514-CMLDM5757TRPBFREECT-ND,1514-CMLDM5757TRPBFREEDKR-ND|CMLDM5757 TR PBFREE|
|HS8K11TBTR-ND,HS8K11TBCT-ND,HS8K11TBDKR-ND|HS8K11TB|
|SIA929DJ-T1-GE3TR-ND,SIA929DJ-T1-GE3CT-ND,SIA929DJ-T1-GE3DKR-ND|SIA929DJ-T1-GE3|
|FDMC7200TR-ND,FDMC7200CT-ND,FDMC7200DKR-ND|FDMC7200|
|1514-CMLDM8002AGTRPBFREETR-ND,1514-CMLDM8002AGTRPBFREECT-ND,1514-CMLDM8002AGTRPBFREEDKR-ND|CMLDM8002AG TR PBFREE|
|US6M1TR-ND,US6M1CT-ND,US6M1DKR-ND|US6M1TR|
|869-1160-2-ND,869-1160-1-ND,869-1160-6-ND|ECH8655R-TL-H|
|ZXMN3F31DN8TR-ND,1034-ZXMN3F31DN8CT-ND,ZXMN3F31DN8CT-ND,1034-ZXMN3F31DN8DKR-ND,ZXMN3F31DN8DKR-ND|ZXMN3F31DN8TA|
|EFC6601R-TROSTR-ND,EFC6601R-TROSCT-ND,EFC6601R-TROSDKR-ND|EFC6601R-TR|
|FDMC7200STR-ND,FDMC7200SCT-ND,FDMC7200SDKR-ND|FDMC7200S|
|846-QS8J2TR-ND,846-QS8J2CT-ND,846-QS8J2DKR-ND|QS8J2TR|
|296-37535-2-ND,296-37535-1-ND,296-37535-6-ND|CSD87333Q3D|
|1801-TSM300NB06LDCRRLGTR-ND,1801-TSM300NB06LDCRRLGCT-ND,1801-TSM300NB06LDCRRLGDKR-ND|TSM300NB06LDCR RLG|
|1727-7275-2-ND,1727-7275-1-ND,1727-7275-6-ND|BUK9K89-100E,115|
|1727-BUK9K25-40RAXTR-ND,1727-BUK9K25-40RAXCT-ND,1727-BUK9K25-40RAXDKR-ND|BUK9K25-40RAX|
|NTMD3P03R2GOSTR-ND,NTMD3P03R2GOSCT-ND,NTMD3P03R2GOSDKR-ND|NTMD3P03R2G|
|HP8KA1TBTR-ND,HP8KA1TBCT-ND,HP8KA1TBDKR-ND|HP8KA1TB|
|1727-BUK9K35-60RAXTR-ND,1727-BUK9K35-60RAXCT-ND,1727-BUK9K35-60RAXDKR-ND|BUK9K35-60RAX|
|IPG20N06S2L35ATMA1TR-ND,IPG20N06S2L35ATMA1CT-ND,IPG20N06S2L35ATMA1DKR-ND|IPG20N06S2L35ATMA1|
| 2156-NDS356AP-NB8L005A-488-ND | NDS356AP-NB8L005A |
| 2156-NDS356AP-NB8L005A-600039-ND | NDS356AP-NB8L005A |
| 2832-FDS6690A-NBNP006TR-ND | FDS6690A-NBNP006 |
| 2156-FDS6690A-NBNP006-600039-ND | FDS6690A-NBNP006 |
| 2156-RFP30N6LER4541-ND | RFP30N6LER4541 |
| 2156-HUFA76419D3ST-ND | HUFA76419D3ST |
| 2156-RF1S17N06LSM-ND | RF1S17N06LSM |
| 448-ISZ0901NLSATMA1TR-ND,448-ISZ0901NLSATMA1CT-ND,448-ISZ0901NLSATMA1DKR-ND,2156-ISZ0901NLSATMA1-ND | ISZ0901NLSATMA1 |
| 2156-BUK964R2-55B/C-ND | BUK964R2-55B/C |
| 448-BSC0403NSATMA1TR-ND,448-BSC0403NSATMA1CT-ND | BSC0403NSATMA1 |
| 2156-BUK7618-55/C,118-ND | BUK7618-55/C,118 |
| 2832-FDS6685-NBCM003ATR-ND | FDS6685-NBCM003A |
| 2156-RF1S15N08L-ND | RF1S15N08L |
| 448-ISZ0501NLSATMA1TR-ND,448-ISZ0501NLSATMA1CT-ND,448-ISZ0501NLSATMA1DKR-ND | ISZ0501NLSATMA1 |
