Question:
What is an actuator?
Answer:
An actuator is a component that transmits external force or movement to the internal mechanism of a basic switch. The mechanism consists of a pushbutton and lever.
Explanation:
An actuator transmits external force and movement to the internal mechanism and is also useful for making the stroke longer and reducing the operating load (operating force) to make the switch easier to use. The table below shows their types.
Many different types of actuators can be attached to the actuator depending on the shape and movement of the detection object, based on a pin plunger. Select the actuator that is best suited for the shape and movement of the detection object.
Quick tips
Only V size switches have actuators (VAL, VAV, VAM) that can be mounted later.
Product category
Switches Basic Switches
Classification
Selection, Characteristics
Related keywords
Basic Switch
Actuator
Pushbutton
Pin Plunger
Lever
VAL
VAV
VAM
Please visit the link below to see this product category on the Digi-Key website
Switches | DigiKey Electronics
Video on Topic
Here’s a video take on the topic if you would like to check it out.
