------Question for SG-8002JA 1.8432M-PHBL3 ROHS Please Put your question below------
Hello Debra,
Welcome to the DigiKey tech forum community.
I found a similar to that in part XC1343CT-ND. Please review the data sheet to ensure it will work for your application as intended.
Have a wonderful day.
Hi debra_rosa,
The XC1343CT-ND is the only part we stock which is the same package type with the same frequency. It’s primary drawback is that it’s frequency tolerance is 200ppm rather than 50ppm. If that is acceptable, then this would likely be the best solution.
If you need 50ppm tolerance, then there’s a possibility that any of these might work for you. They would only have a chance work if your pad layout happened to be laid out as specified in the datasheet for your part.
SG-8002JA specified pad layout:
CB3-3C-1M843200 specified pad layout:
