What is connector for GP2Y0E02A Infrared Sensor
I ordered this GP2Y0E02A IR Sensor but realized it didn’t come with a wire. Was wondering if someone would know what kind it is?
The GP2Y0E02A IR sensor uses small SMT-style pads. It has four pins: VDD, GND, Vout, and GPIO1. You can solder wires directly to these pads safely.
Some versions include a bare-ended cable, not a standard jumper. A 4-pin JST PH connector works well too. This allows easy connection to controllers and removable wiring.
For practical guidance, check projects like Interfacing IR Sensor Module with Arduino Nano. They show proper wiring and usage examples. Always verify voltage and decoupling capacitor needs.
@brian.le9822 Welcome to DigiKey TechForum!
This forum post may help you:
