Simulation-based magnetic field analysis predicts that a magnetic flux density can be reduced to several mT by moving the sensor approximately 20 mm away from the surface of the relay housing.
❚ G9KB-1A
❚ G7L-2A-X
❚ G5PZ-1A-X
❚ G2RG-2A-X
Return to this FAQ title page
Easy-to-understand explanations of the unknowns when using high-capacity power relays
Section 5 of 9
https://components.omron.com/us-en/solutions/relays/power-relays-support
