Trying to figure out what this resister is the color code is really messing me up can any one give me a idea and where to find it please.
Colors are , black red red silver brown
Reads as a .22 ohm 1% but cant find it any where
Hello Rossetti1,
It appears that you have the value listed correctly. We have the less than 1 ohm resistor listed as mOhms. In this case that would be a 220mOhm resistor. We really only have one option in stock in our part MRA05-.22-ND
The only thing that I am unable to verify is the power rating of the resistor you have. Our part is rated to 4 Watts.
If you’re asking what the power should be, I use this chart:
along with a color code quick guide for figuring everything out.
Hello MDmrse,
Yes this is a good resource for figuring out what the Ohm rating and tolerance of the resistor is, however it does not tell you if the resistor is a 1/10th watt or 1/4 Watt or 1 watt resistor. That is what I was referring to by power rating of the resistor.
