I need help identifying a resister
Hello, welcome to the Techforum! The color code for this resistor looks to be for a 9.2kOhm resistor with a 10% tolerance.
Thank you Rob for the quick response.
Marc
Actually!
Any suggestions as to where I should buy a replacement online?
Not finding 9.2K Ohm Ω 10% Tolerance anywhere online.
Currently we have these in stock, they are relatively close and have 5%or less tolerance so should be pretty close to the range of the original, check the datasheets and see which one will work best in your application
