Do you think this is a 22 ohm resistor? Wondering what the “black” is on the smaller resistor. Could it just be a burn? Any ideas on the value on the smaller one?
Black is definitely burned; the smoke was let out…
But yeah the small 1/4 wat resistor appears to be a 22 ohm
Larger one Brown, black, white, gold is evident when click on it twice (really enlarged). 1giga ohm seems unreal. idk, I would say these are specialized resistors
I would say the Larger one is Brown Black Silver Gold, which gives a 0.1 Ohm 5%
The smaller seems like black red red gold, but a leading 0 is not possible.
So maybe Blue or Brown.
Which makes it either 6.2kOhm 5% or 1.2 kOhm 5%.
1/4watt smaller one on right
normally you have three bands and tolerance. Unable to see what the first band color is…
http://education.rec.ri.cmu.edu/content/electronics/common/resistors/1.html#Read_Resistor
It could be a color range from black to white for the first band which that is burnt away :@O
