I’ve done my best to try to identify the colors but they are flaking off and I am not a hundred percent sure. Plus I usually work with surface mount components not thru hole so I don’t really know where to begin.
Any help is appreciated, thank you in advance.
EDIT
I looked at it closer under the microscope, and I think there might actually be 5 bands with the colors:
1: BROWN
2: PURPLE
3: BLACK
4: SILVER
5: GOLD
Could this type of resistor fail to be like 63 ohms cause that is what it tests at right now, its clearly burnt though but I’m wondering if its current value could rule or its original value since I am guessing a bit on the colors?
