------Question for 18440 Please Put your question below------
I, what is the revision for item
18440 SparkFun Electronics | Expansion Boards, Daughter Cards | DigiKey
For the 1568-18440-ND (18440)the documentation I find for it shows that these would be a 2.0 after 2016. From what I can tell we added these sometime after that.
However, I would not be able to indicate for certain what date codes / version of the items we have on hand.
When you order, you can add to your order notes a request that the items be made newer than 2016. The warehouse will try to accommodate that request and will let you know if they cannot.
B0068.pdf (3.0 MB)
I need to be revision F
When you order these you can add that to your order notes.
