We often get questions wondering what is included with the purchase of a PICOGLF30W24V120VR inverter from AIMS Power. Buried halfway through a lengthy datasheet you can find the below answer:
3.1 Unpacking and Inspection
Carefully remove the inverter charger from its shipping package and inspect all contents.
Verify the following items are included:• The PICOGLF Inverter Charger
• Red and black DC terminal covers
• AC terminal block cover with two Phillips screws
• Two Flange nuts and 4 Phillips screws (installed on the DC terminals).
• PICOGLF Series Owner’s ManualIf items appear to be missing or damaged, contact AIMS Power. If possible, keep your shipping box and all packaging. It will help protect your inverter from damage if it ever needs to be returned for service. Save your proof-of-purchase as a record of ownership; it will also be needed if the unit should require warranty work. The serial number is on the side of the inverter and does NOT start with an 8.
Please note this is a Marketplace product and therefore it is shipped from a third party, not DigiKey, and not available in all markets. For more information on Marketplace products please see: DigiKey Marketplace
