Inverter help
Hello, I need an inverter sine wave that can run a unit with these specs
AC INPUT VOLTAGE: 100V-240V, 50/60Hz, 1.7-0.6A
DC INPUT VOLTAGE: 12/24V, 6.5A
Will the PVINT375 be the correct inverter for this job?
PVINT375
you have
Continuous Output Capacity (Watts) 375
Peak Output Capacity (Watts) 600
so if you are looking for a higher continuously rating you may want to look at a higher wattage
