Which are the waterproof tactile switches?
Question:
Block
Answer:
Waterproof tactile switches have an IP67 equivalent rating and also go by sealed switches.
Omron’s waterproof (IP67) tactile switch models are as follows:
B3W, B3S, B3SL, B3SN, B3SE, B3WN
Block
Explanation:
Among models with a degree of protection equivalent to IP67, B3W/B3WN are through-hole type and the others are surface mount type. The types with ground terminal and gold plating are as follows:
With ground terminal: B3W, B3S, B3SN
With gold plating: B3SN
Block
Quick tips
Although they have the sealing performance equivalent to that of IP67, please note that they cannot be used in an environment where water droplets stick constantly (for a long period of time).
Product category
Switches Tactile Switches
Classification
Selection, Characteristics
Related keywords
Tactile Switch
Waterproof
IP67
Ground Terminal
Gold-Plated
Block
Please visit the link below to see this product category on the Digi-Key website
Switches | DigiKey Electronics
https://components.omron.com/us-en/faq/switches/FAQE20062
