Hi!
NXS0506GUX output is push-pull. Why is there no <Non-inverted?>
NVT4858HKZ output is just . Why is there no <push-pull?>
As far as I understand the datasheets, both ICs should have push-pull and non-inverted output types.
Or is it a mistake?
Hi!
Or is it a mistake?
Welcome to the DigiKey TechForum. I’m checking into this and will post the information when I receive it.
That field and many others like it contain known inconsistencies, as a result of imperfections in curation over the course of 30 years. Examination of values present in the column will show at least 3 different concepts (logical inversion, output transistor structure, output format) being referenced which could potentially be described for all products in the family, though not all entries carry an annotation for each.
Narrowing selections based on other, less-confused criteria first is a useful technique for coping with such things.
