World’s Smallest FPGA SoC from Microchip
use Scalable Performance with different architectures
Should You Use an FPGA System-on-Chip ?
YES! If You ….
• need parallel processing
• might need PCB rewiring
• need a lot of glue logic
• have hardware that is safety critical
• demand software independent HW
• are doing pre-development
• create new MCU peripherals
• must change existing peripheral behavior
• run ‘C’ code in an FPGA
Unleash Firm-Ware Developers
The FPGA SoC Solution makes it safe !
FPGA SoC Redefined
Configuration Process – using MCC Melody
https://www.microchip.com/en-us/tools-resources/configure/mplab-code-configurator/melody
1st step in config Process
2nd step in config Process
If you are Very veri interested in soldering the miniFPGA kit together – it is online available:
https://www.digikey.com/en/products/detail/microchip-technology/VERYVERILOG/29020656
and more information as NPH:
https://www.digikey.com/en/product-highlight/m/microchip-technology/very-verilog-a-mini-fpga-kit
Here’s the link to the video recorded at Microchip’s office meeting room – Bavarian lake(s) – from our German students ambassador Tobi:
