Looking at a material test array physically shows you exactly how the material will respond to different power and speed settings. Even if your material is known to xTool Studio, doing a material test array is still worth it. There is only so much that can be gained from the image in xTool Studio.
The steps outlined in this guide will show you how to perform a material test array in xTool Studio v1.10.15 and will use the xTool P3. The material test array is not limited to the P3.
How to Set Up a Material Test Array
Before starting the material test array, a subject matter is needed. While xTool Studio does have a default design for the material test array, using a design of your own can beneficial to see how it looks.
First select the material if it is known to xTool Studio. Then draw a small rectangle by pressing “R” on the keyboard and drawing it on the work area. It should be big enough that the result is clear and the depth can be measured with a caliper. For this guide the rectangle is 7mm x 3mm. To resize the rectangle select it and use the tool bar that appear at the top of the workspace.
Next select the rectangle that was created, then set the preset to engrave. This will align the setting in the default settings in the tool with what wants to be tested.
After the engrave preset is selected, click on the Useful Tools and Generators icon shown below.
Next Select the Material Test Array from the Efficiency Tool selection.
This opens a new window that allows you to change the parameters for the material test array. The default grid for the material test array is 5 by 5 with a 2 mm spacing. When the parameters are changed, the tool updates the grid automatically.
For this test array run change the minimum speed to 100. From past experience, if the speed for acrylic is too low, the material or acrylic vapors can catch fire thus causing a hazard and ruining the results. Once the test has been performed you can run the test again on a new location with different parameters.
Once the parameters are set to click done and then position the material test array to where you want it done. Lastly before processing if the material is known to xTool Studio, create another rectangle around the test array and set that process to cut. This will allow the material to be separated and be stored on hand for future reference.
Material Test Array Results
Here are the results of the material tests that I have completed.
