I am planning to use 3.7V lithium battery as a replacement for old one in cordless screwdriver.
Does anybody can recommend simple soldering charger kit for lithium battery.
Welcome to the TechForum.
Are you looking for the battery only or a soldering kit for this? I have battery options below.
21700 battery options
https://www.digikey.com/en/products/filter/batteries-rechargeable-secondary/91?s=N4IgjCBcoMwExVAYygMwIYBsDOBTANCAPZQDa4ALAKwCcNAHCALqEAOALlCAMrsBOASwB2AcxABfQmAY1EIFJAw4CxMiAAMzcZJAJI5GADoA7ADUtQA
Thank you
Ryan
Hello Ryan!
I am looking for soldering charger kit with components and circuit board for lithium battery
Vr.
Dmitri
There are some products here that might be of interest.
thanks for the information for open frame charger!!
But, they all less than 2 amp charging current.
But, my battery selection is a Standard Continuous Charging Current: 2.5A.
I need Standard Continuous Charging Current to be 2.5A !!
Dmitri
Perhaps something like the MIKROE-6653 or something from this category?
David,
Thank you for the information!
you advice is good if I need to control and adjust Voltage and Current on a computer monitor! But, it is too complex!
I found this circuit diagram. It is allowed change charging voltage. I need similar with ability to change charging current also with variable resistor and input AC 110V .
Unfortunately I’m not seeing anything viable, it looks like Rick and David have already found the most likely products in our catalog.
ok, Thanks!
Dmitri
