3-phase Cubic Capacitor
Dear Sir/Madam,
We are interested in purchasing 10 three-phase power capacitors (EPCOS/TDK) with the following specifications:
Rated power: 50 kVAR
Rated voltage: 420–480 V AC
Frequency: 50 Hz
Application: Reactive power compensation
Would you please help us find the most appropriate product.
Thank you in advance for your feedback.
Hello @faraeurope,
Welcome to the TechForum.
DigiKey offers a variety of EPCOS/TDK power factor correction capacitors. Here is a representative example:
Regarding KVAR selection, please refer to selection tables found in datasheet such as this.
It may be necessary to use several capacitors in parallel to achieve the desired kVAR. Consider adding control circuitry to add capacitors as necessary as your load changes.
Sincerely,
Aaron
Dear Aaron,
Thank you very much for your kind and detailed reply.
Please note the following:
  1. The operating frequency is 50 Hz.
  2. The main point is to increase the voltage to help a little against the effects of harmonics, not to increase the capacitor power, of course, in this request.
  3. Our request is not exactly for 480 volts, but 420 to 480 volts, if I’m not mistaken, or 440 to 480.
  4. We are not looking for a harmonic filter check at the moment, we want to have the capacitors only.
Hello faraeurope,
Without a capacitance value, I can not narrow down the choices.
Click here for some available options.
These are 3 phase film capacitors, that can handle 480V or higher.
Please check the datasheets to verify compatibility to your application.
Dear David,
The capacitance required is 332mf per phase.
Dear David,
Would you please check these two models.
B25675C4502J040 for 440VAC or
B25675C4502J080 for 480VAC
