3 position ZH header for jst connectors
Hi! Is this a 3 position header for jst zh series? Thanks!( it is partially damaged). Brad.
Thank you for posting on the TechForum.
Those pictures are not clear enough for me to try to ID the connector.
Hi! Here are new pictures! Thanks!
Part number 455-1720-ND is the closest match I found
S3B-PH-K-S JST Sales America Inc. | Connectors, Interconnects | DigiKey
These are the other options I found.
Header 3 Headers, Male Pins | Rectangular Connectors | Electronic Components Distributor DigiKey
If you can measure the pitch on the contacts, you can narrow down the list even more.
