I wanted to check in about the Ebelong D1 DOOR KINETIC ENERGY HARVESTING R
The questions I would have:
as I don’t see if this is the pure RF version or either the ZigBee or the WiFi version, and the manufacturer site suggest that it exist in different variant want to check which variant is being sold trought DigiKey
If it’s only RF then want kind of receivers are compatible with it, either for switching or just signals
It’s designed to be surface mounted, but I would prefer to build it into the door itself, would it cause operational issues, for example overheating, or lost signal ?
Is there a signal receiver which is compatible with home automation, for example an USB receiver to Home Assistant or an MQTT relay HW or any other way to hook it up to something smarter then a ON/OFF switch
