Can you recommend a replacement for: 78602/9C (digikey:811-1266-5-ND}. thank you
I see there are a number of those currently in stock. Is there something you are looking to change or a different manufacturer?
I heard that the part might not be produced in the future. I want to see if I can get from other manufacturers or replace it with an equivalent part,
That is the only part we carry with the those characteristics in through-hole. However, we do carry essentially the same part in surface-mount in much larger quantities.
Specifically, the 78602/9JC, which comes in tube packaging, and also the 78602/9JC-R, which is the same part on a reel.
