About the Fans, Thermal Management category
Thermal Management Product Support, FAQs, and other topics.
I’d like to purchase the Sanyo 109R0848K401 fan. I cannot tell from the data sheet what the yellow wire outputs during a fault. Is it a 0-5V signal, a 0-48V signal, etc.
Thanks,
Mike
Welcome to the technical forum. I have sent this request to the Product Specialist. I will let you know when he responds.
See attached. The Voh is based on the pull up voltage used by the customer. They can use any voltage between 0~60V however most of our customers just use the 48V power line to match the fan operating voltage.
109R0848K401_D.pdf (103.1 KB)
The yellow wire is typically an open-collector output that pulls to ground during a fault. Always check the datasheet for the maximum sink current to determine the correct pull-up resistor for your control logic.
