I need a BNC to accelerometer cable. The accelerometer interface is 1.2 UNM. The type of acceleromater is endevco 2250A-10. I tried a search on your web site and came up with nothing.
Welcome to the Tech Forum!
I was also not able to locate that type of cable in our system. We have similar 10/32-BNC options, but I do not believe they are for this purpose. I did include the link below and they still would need a male-to-male adapter for the connection. Hopefully next time we will have exactly what you need.
Thank you
Ryan
Have you checked with Endevco directly? They might have what you need or recommend a supplier.
I searched on their site, but couldn’t find a way to contact them directly.
Thanks,
Lynnane
Can you recommend a vendor who might?
Lynnane
We do not carry Endevco part. We would not know who distributes for them.
Hi lgeorge2,
Can you clarify just what the terminating connector on your accelerometer is. Looking through some documentation, such as pages 1 and 3 of the datasheet for the 2250A-10, it appears that the accelerometer typically comes with a cable, the “3006-120”, which has a “10-32” plug on the non-accelerometer end.
If you have this cable, then might the PE9750, a 10/32 Jack to BNC plug adapter work for you?.
I am not certain, but it appears that a “Microdot” connector is equivalent to a “10-32” connector. If so, then the 51S131-K00N5
or the 8194352A042
might also be options.
Thanks!
Lynnane
