Finding correct BNC plug
What are the correct BNC connectors to use with BEL1259-100-ND cable?
I purchased some ACX2299-ND with the cable but they do not fit. The core conductor is too thick for the pin. Need a connector that can handle up to 6GHz.
howard.scott
The BNC connectors we have to offer for that series of cable are part numbers 2201-R142077732-ND this is non-stock with a 100 pc minimum , and part number 2201-R142077732W-ND also non-stock with a 50 pc minimum .
Thanks Craig
Consider also these options.
The “Cable Group” parameter indicates the style(s) of cable material with which a given coax connector is compatible. Using the in-column search function can help in locating the various values to be selected.
