Analog Devices Inc. Solution - Power Attached and Optimization – Methodology for RF Signal Chain Systems - please check out this link as well:
Interactive RF Signal Chain – ADI & Digikey
AD9213BBPZ-10G is a 12bit PIPELINED ADC (Analog to Digital Converter) in 192BGA (12x12) with a sampling rate of 10,25 Giga Samples Per Second (GSPS) for ADEF (Aerospace and Defense) applications
AD9217BBPZ-10G is a 12 bit ADC JESD204B+ HIGH SPEED compliant
AD9208-DUAL-EBZ is a DUAL AD9208 EVALUATION BOARD
AD9172-FMC-EBZ is an EVAL BRD KIT for AD9172
AD9650-105EBZ is a BOARD EVAL for AD9650
ADF5610BCCZ is an already Obsolete IC INTEGER-N/FRACTIONAL 48LGA and we recommend as replacement
EV-ADF4372SD2Z as Frequency synthesizer Timing Evaluation board
AD9081BBPZ-4D4AC is a MXFE QUAD 12 GSPS RFDAC QUAD 4GS
ADRV9009-W/PCBZ is a DUAL RF RX/TX/ORX EVALUATION BOA
ADRV9008-1W/PCBZ is a DUAL RF RX EVALUATION BOARD
ADRV9008-2W/PCBZ is a DUAL RF TX/ORX EVALUATION BOARD
ADRV9002NP/W2/PCBZ is an EVAL BOARD for ADRV9002 with 3GHZ-6GHZ
ADRV9002NP/W1/PCBZ is an EVAL BOARD for ADRV9002 with 30MHZ-3GHZ
ADRV9029-MB/PCBZ is a MID BAND EVAL for 650MHZ-2.8GHZ
HMC8413LP2FE is an IC AMP RADAR 10MHZ-9GHZ 6LFCSP
ADL9005-EVALZ is an EVAL BOARD for ADL9005
ADPA7008AEHZ is an IC RF AMP GPS 20GHZ-54GHZ 18CLCC
ADL8106ACEZ-R7 is an IC RF AMP GPS 18GHZ-54GHZ 24LGA with corresponding ADL8106-EVALZ
HMC994APM5E is an IC RF AMP 0HZ-28GHZ 32LFCSP
