Is there a substitute for this relay that could be used. It is for a control board on an ice maker.
Thanks in advance
Thanks in advance
Hello Gary,
Thank you for using the Digikey Tech Forum.
These relays on the Link are the closest crosses I could find.
Please use the datasheets to decide with part will work best for your ice maker.
For reference here’s the page for the part, it may help you find an available substitute (I suspect you’d have to order dozens or more to buy it from Digi-Key).
Thanks,
Gary
Was practicing using the view similar feature and it appears there’s a marketplace seller with the product but with small difference in the Manufacturer Product Number but the same data sheet.
Hello gary1,
I see we do not carry the 9VDC relay you are looking for.
The closest alternate I found is 2449J107F1AS129VDC.36-ND.
If you check the datasheet, you can verify this should have the correct pin locations, and spacings.
This one can handle 12A of current instead of 10A, so should be an upgrade.
Thanks,
Gary
