We do not currently carry the KLPX-0848A-2-R-G barrel connector from Kycon, Inc., however we do have a similar alternative below. The difference between the parts is as follows:
blank=barrel, pin 1: Nickel - Layout1
G=barrel, pin 1: gold flash - Layout1
Please review the datasheets to ensure the alternative will work for your application.
| MFR PART # | KLPX-0848A-2-R |
| DIGIKEY PART # | 2092-KLPX-0848A-2-R-ND |
| MANUFACTURER | Kycon, Inc. |
| DESCRIPTION | 3.20mm ID, 9.00mm OD (RCA) Phono (RCA) Jack Mono Connector Kinked Pin |
