The cable assembly above is listed obsolete in our system. This is a USB to TTL serial cable that is 6 feet long, shielded, and is rated for 3.3V. Here are the following specifications that are considered key attributes:
Usage: USB to TTL Serial 3.3V
Convert From (Adapter End): USB-A (USB TYPE-A), Plug
Convert To (Adapter End): Cable, 6 Wire Leads
With these specifications, the following link can be found on our website for alternative solutions:
These options have a few differences such as the shielding and the cable length. The original appears to be 6 feet (1.83m) long and these options are 5.90 feet (1.80m) long. The original cable shows that it is shielded, whereas these options are unshielded.
With the link provided above, those cables appear to be the closest options we have that are active in product status. Hopefully this will help in choosing an alternative smart cable.
Please review the datasheets to ensure the alternative will work for your application.
