ActiveBOM is not showing DigiKey link or prices correctly. Its Favorite suppliers shows show DigiKey as a “Lost” supplier or “Risk” supplier. It however works fine in the Manufacturer Part Search. The image shows the issue.
Just to add the Altium version I use is 25.2.1 . I always set Digikey as my 1st supplier. But with this issue all my BOMs are messed up.
Have you brought this issue up with Altium? It could be an issue with their API. This is not software that DigiKey has control over.
Altium support
Hi Steven, Thanks for your reply. I have brought it up with Altium. Their reply was that this issue does not meet the justification for critical impact. Hence they are not addressing this because I have standard subscription for Altium (not Pro).
Apparently Standard subscription customers can only create support case if they are facing an issue that has critical impact on their business as per their recently changed support option for Standard subscription customers. Not very convenient.
