Amphenol Receptable 200A 50sqmm terminal info
Hi,
I need support on a Amphenol connector and to be more precise ER225011.
  1. I want to know if you have this connector in stock since on the website is not appearing.
  2. I want to know if i can order only terminals 11.1 since i ordered connector ER22BB11 and that have busbar terminal application on our current design that can not be implemented. Please can you share the terminal number.
Many thanks in advance for your support,
Alexandru
Greetings,
In response to your questions,
  1. No, the requested connector is not an in-stock item.
  2. The datasheet for the part series lists accesories and replacement parts on page 7.
Those 11.1mm pins can be found listed under Rectangular Connector Contacts, and the larger two sizes are in stock at the moment.
Hi,
Many thanks for quick replay. Is unfortunate that PIN-11-50 is not available on stock. In my previous email i mentioned terminal size of 11.1mm but I might need PIN-08-50 instead since i have connector that support 200A ER22BB11 so in my case for 50sqmm wire terminal of 8mm should be ok. the 11.1 terminal probaly is used on 400A ER425011 on a 50sqmm wire.
Thanks a lot for all the support.
idriceanualexandru
Here is a link for all the ePower contacts we have to offer , sorry we do not have the PIN-08-50 in stock
Rectangular Connector Contacts | Rectangular Connectors | Electronic Components Distributor DigiKey
Thanks Craig
Hi,
Sorry to hear that you don’t have any of pins available in stock.
Can you confirm that connector 200A EP225011 is coming in the kit with pin insulation of 8mm? What about 400A EP425011 is that supporting 11.1mm?
