Ams OSRAM AS7058
Hi,
I would like to know how to register for full implementation data sheets for the AS7058 and AS7057. I tried emailing support and they told
Me to post here.
Best
Mark
Welcome to the Technical Forum. I would say to submit a request using this form on the AMS website: Technical support | ams OSRAM
Contacting the Supplier is the only way you will be able to get access. Hopefully this form will help.
Hi mpwirwin,
This may not be what you’re looking for, but have you taken a look at the available documents here, and in particular the AS7056_57_EVK_UG001039_1-00 ?
That document covers a lot of detailed info on the AS7057.
Likewise for the AS5708, this page looks like a good source for information. In particular, again, the AS7058_EVK_UG001052 looks useful.
Also, there are a few evaluation kits which might help with the evaluation/development process for these biosensor devices.
Hi, as a supplier I thought you have a good day to register with the supplier, hence why I reached out privately. I tried to contact them direct and got no response.
I had the same problem with Osram support webpage… they do not take any request into consideration if you’re not a direct Osram customer. As an Osram chip user, you rely on your distributor willingness to reply and scratch one’s head, which is likely not to happen. Good luck
