Analog Multipliers, Dividers
This Product Selection Guide contains information to help select products in the Analog Multipliers, Dividers category on DigiKey.com
Analog multipliers take two or more analog signals and produce an output which is their product or the sum of multiple products. Such circuits can be used to implement related functions such as squares (apply same signal to both inputs) and square roots. Applications may include variable gain amplifiers, ring modulators, product detectors, mixers, gain control, true RMS converters, and pulse amplitude modulators (PAMs).
SelectionCharacteristics
Function: Describes main function or usage of the circuit.
Number of Bits/Stages: Indicates the number of quadrants (combinations of operand sign/polarity) within which a device can operate.
Package / Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
MFR PART # Analog Devices Inc.
DIGI-KEY PART # 505-AD633JRZ-ND
MANUFACTURER AD633JRZ
DESCRIPTION Analog Multiplier 4-Quadrant 8-SOIC
DATASHEET Click Here
MediaLinks
Videos
Analog Multiplier
Analog Divider
Articles
The Fundamentals of RF Power Dividers and Combiners
Divider
Analog Multiplier
Analog Divider
Product Training Modules
Analog Multiplier
Analog Divider
Blogs
Analog Multiplier
Analog Divider
TechForum
Multiplier
Divider
If you have any general questions on the specifications for selecting Analog Multipliers, Dividers, please reply using the button below. If you have questions on specific Analog Multipliers, Dividers please post those questions in the Integrated Circuits (ICs) category.
