Are there variations in which directions tactile switches can be pressed?
Question:
Block
Answer:
The standard models are top actuated tactile switches, but there are some side acutatued types also.
Block
Explanation:
The lineup of horizontal push type (vertical type) is as follows:
B3F: Standard DIP terminal (through hole terminal)
B3U: Surface mount, very small type
Pressing the switch diagonally or laterally against the plunger may damage the contact dome or reduce its durability.
Block
Product category
Switches Tactile Switches
Classification
Usage, Applications
Related keywords
Tactile Switch
Vertical Type
Horizontal Push Type
Block
Please visit the link below to see this product category on the Digi-Key website
Switches | DigiKey Electronics
Are there variations in which directions tactile switches can be pressed? | FAQ | OMRON Device & Module Solutions - Americas
